Project "Envy" - Page 33 - JeepForum.com
post #481 of 551 Old 06-08-2012, 08:46 PM Thread Starter
bbc
I got the power steering pump lined up with the other pulleys and it is tracking straight now. It was in there a little crooked due to it being a bigger moded pump and it was hitting one of the four bolts that hold the accessory bracket to the engine. Also the Engine was being a little hard to start and had a erratic idle. I had a couple of the crank sensor wires crossed. fixed that and it is starting/running/ idling great now.
bbc is offline
post #482 of 551 Old 06-28-2012, 07:43 PM
Skerr
Hey Sh-Sh-Shaun... wh-wh-wh-what's up? You s-s-s-sell your Jeep?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #483 of 551 Old 06-28-2012, 09:03 PM Thread Starter
bbc
Never Sell!
I have been busy with work and moving. The Jeep is Safe in Another Man's Garage, as I don't have A Safe place for it right now. I haven't seen it in two weeks. I plan to visit It soon when I get my hands on a scanning tool. I need to find out what codes it throwing and go from there. Then I will start thinking about the transfer case and rear axle.
I'm still here, you will see this thing finished. I promise.
bbc is offline
post #484 of 551 Old 06-28-2012, 10:39 PM
Galt
Galt's Avatar
1983 CJ7
Originally Posted by bbc View Post
Never Sell!
infamous last words.
Good luck with her.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #485 of 551 Old 06-29-2012, 06:42 AM
Skerr
... get my hands on a scanning tool. I need to find out what codes it throwing and go from there... I'm still here, you will see this thing finished. I promise.
http://www.jcwhitney.com/obd2-can-co...wx?filterid=j1
Hurry Up!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #486 of 551 Old 06-29-2012, 08:31 PM Thread Starter
bbc
Good luck with her.
I'm not going anywhere, I just renewed my forum membership. I just got to get settled in and then it's jeep time.
bbc is offline
post #487 of 551 Old 06-30-2012, 08:42 AM
cjjon7
1983 CJ7
Almost done with my Attempt at the duct modification. I have to trim the hose a little and screw the upper pipe up.
Instead of cutting the lip off the heater box like the first one shown and screwing a flat piece on top, I wanted to retain the lip just in case. So, I made a slip on piece out of sheet metal that I will silicone on and hold it with a few sheet metal screws from the front. I think it will work out fine. Gauges should fit now. Everything was found at Home Depot for about $20
Funny how everything snowballs and one thing leads to another.
Sorry for the ignorance, but im having a brain fart. Im trying to think how the stock setup is, because I really like this idea, and why the need for the 24" long pipe? Why not just make it the 1' section where the defrosters are and omit the rest? What am i overlooking???
-Also, what steering shaft are you running?? That thing looks tough!
cjjon7 is offline
post #488 of 551 Old 06-30-2012, 09:59 AM Thread Starter
bbc
you could use a shorter section if you just wanted to replace the old ducting, but if you want to add some gauges above the old oil and volt gauges, the ducting will interfere. that is the reason for the longer pipe to get the ducting farther to the right to make room for additional gauges.
The steering shaft is a borgson heavy duty shaft with damper.
bbc is offline
post #489 of 551 Old 06-30-2012, 12:56 PM
cjjon7
1983 CJ7
Awesome thanks alot for that. Off to Lowes!
Got it built, how did you secure the hose into the fittings, just silicone it in there?
cjjon7 is offline
post #490 of 551 Old 06-30-2012, 08:49 PM Thread Starter
bbc
silicone and a few screws through the PVC into the hose to hold it in place.
bbc is offline
post #491 of 551 Old 07-07-2012, 09:00 PM Thread Starter
bbc
New Scanning tool should be here next week sometime, and then its ON! It's been to hot out to work on anything this last week. I tried starting it one evening last week and the idle was low again. I thought I had fixed that with a TPS reset, but I guess not. The Wife was 3 houses away when I started it up, and she said it sounded really mean!
bbc is offline
post #492 of 551 Old 07-07-2012, 09:02 PM
Skerr
I can see everyone run to their window... "Is it going to rain?" It IS really mean. Keep us posted.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #493 of 551 Old 07-09-2012, 08:59 PM Thread Starter
bbc
The verdict is in, I got a P1336 Code
bbc is offline
post #494 of 551 Old 07-09-2012, 09:34 PM
lucdog
lucdog's Avatar
1980 CJ5
And that means ?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #495 of 551 Old 07-09-2012, 11:02 PM Thread Starter
bbc
Originally Posted by lucdog
And that means ?
Bill
DTC P1336 Crankshaft Position (CKP) System Variation Not Learned.
And if that's the case, then I need either the GM Tech 2 scanner to do it or bring it in once it's driving to get it done.
I'm going to give PSI performance a call seems I got the ECU and harness from them and see what their support has to say.
Other than that- that was the only code and it started right up today, but idled a little low. I need to adjust that a bit.
bbc is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 799 06-19-2015 05:28 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
