Project "Envy" - Page 29 - JeepForum.com
post #421 of 551 Old 04-25-2012, 12:32 PM Thread Starter
bbc
Almost done with my Attempt at the duct modification. I have to trim the hose a little and screw the upper pipe up.
Instead of cutting the lip off the heater box like the first one shown and screwing a flat piece on top, I wanted to retain the lip just in case. So, I made a slip on piece out of sheet metal that I will silicone on and hold it with a few sheet metal screws from the front. I think it will work out fine. Gauges should fit now. Everything was found at Home Depot for about $20
Funny how everything snowballs and one thing leads to another.
bbc is offline
post #422 of 551 Old 04-25-2012, 12:53 PM
Jim1611
Jim1611's Avatar
Nice work.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #423 of 551 Old 04-25-2012, 02:09 PM
Skerr
I thought the pedals were cool, but now you just blew me away with your ducting! And no details?? C'mon Man... I gotta do that!!! I NEED MORE! Parts? Fittings? etc, etc, etc...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #424 of 551 Old 04-25-2012, 02:37 PM
2girlsAndaGuy
1979 CJ5
oh your defrost mod is just what I'm looking for. I had my double d dash in the other night and the speedo was interfering with the stock setup. I'd love to hear a little bit more about what you used!
David
2girlsAndaGuy is offline
post #425 of 551 Old 04-25-2012, 02:56 PM Thread Starter
bbc
I will pull it all back out tonight and lay it out and take a few more pictures for you guys.
bbc is offline
post #426 of 551 Old 04-25-2012, 05:45 PM Thread Starter
bbc
OK, First off - In no way am I taking credit for this Idea. I found it searching on here. I don't remember who did it first. So if it was anybody looking at this, Feel free to take your dues. This is what I did after studying your pictures. Hope it helps others. I did this so I could fit 3 other gauges above the oil & volt gauges and have clearance.
Parts list-
- 2 ft piece of 1 1/2" black ABS or PVC your choice ( use same color fittings)
- 2 end caps
- 2 short Y fittings
- 5.5" X 4.5" piece of sheet metal
- 2 Adapter 1 1/2" to 1 1/2" thread
- 3 ft. of hose of your choice
All was found at home depot.
-glue pieces together to resemble photo- needs to be 24" assembled. You might have to grind down the joints a bit on the sides to fit it flush under the dash
- after it's dry, put it in the table saw and cut it in half.
- bend and work your sheet metal to fit around and over the box opening. Then drill holes in it for the Threaded Adapters and screw them in
- fit it up under dash , the end should be about 43" from drivers side end of dash to clear the glove box.
- drill your 2 holes from the top and screw in place
image-2823018258.jpg   image-899990794.jpg   image-2328933343.jpg   image-229696401.jpg   image-1581424526.jpg
image-4235558034.jpg   image-3124487695.jpg   image-2762235040.jpg   image-3443155499.jpg
bbc is offline
post #427 of 551 Old 04-25-2012, 08:19 PM
2girlsAndaGuy
1979 CJ5
Thanks for the write up, that will help a ton! Great job by the way.
David
post #428 of 551 Old 04-25-2012, 10:23 PM
Skerr
So the half pipe fits snugly under the "whatever-it's-called" part of the cowl? Did you use any foam for a better seal? How did you anchor it... using a long screw right through it? That's Kick-Butt Shaun! Thanks for posting it. I wouldn't have thought to do that on my best day.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #429 of 551 Old 04-25-2012, 10:49 PM Thread Starter
bbc
2 Screws, About 1 1/2" with a washer and nut. Down through it in the original locations.
The Original one did not have any foam. I thought about it. but it's pretty tight up there. I might use some black silicone around the edge before it goes in permanently.
bbc is offline
post #430 of 551 Old 04-29-2012, 06:58 PM Thread Starter
bbc
dash is almost done. just waiting on a tach.
Made a plate for the 5" speedo that mounts from behind like the original speedo with the 4-5/8" hole in it that was needed. Also made trim rings out of door knob protectors made to mimic the black center overlay for the Clock/Tach. These were needed due to the tach hole being a little to large for a new 2-5/8 tach.
Wiring harness and ECU, Hopefully next week.
image-3912300477.jpg   image-307617589.jpg   image-1501002077.jpg   image-3130168941.jpg   image-3483280920.jpg
bbc is offline
post #431 of 551 Old 05-01-2012, 02:32 PM Thread Starter
bbc
Tach came!
with my fabricated trim ring and the use of the old tach cup, got it all buttoned up.
I also put red LED's in all the gauges.
bbc is offline
post #432 of 551 Old 05-01-2012, 04:03 PM
2girlsAndaGuy
1979 CJ5
looks great except that your clock is crooked.
David
post #433 of 551 Old 05-01-2012, 04:12 PM Thread Starter
bbc
Ya, I adjusted it. good eye though.
bbc is offline
post #434 of 551 Old 05-01-2012, 04:15 PM
Coiz
1979 CJ7
Great idea on the trim rings. Looking forward to the night shot of the dash.
Mike
Coiz is offline
post #435 of 551 Old 05-01-2012, 06:40 PM
Skerr
Pretty smart innovation Bud. You keep giving me all of these cool ideas, and I'm never gonna remember them! I'm with Mike... waiting for the night picture of the dash. Maybe tonight??
Kerrdog
Go Fish! <*////><
Skerr is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
