Project "Envy" - Page 28 - JeepForum.com
post #406 of 551 Old 04-15-2012, 04:59 PM Thread Starter
bbc
Going to Order the Wiring harness this week for the LS2.
Im still working on the dash and gauges. I'm going to go a different route with the gauges than I originally intended. The Original Volt & Oil gauges are not cooperating with me. While trying to give them a new look the needles just crumble on me due to Sun damage and age. I'm going to go with some Auto Meter Gauges and now add a Tranny Temp gauge as well. With Separate Fuel, Volt, Oil pressure, & Water temp gauges. Its going to be nothing but wiring for me for a while.
bbc is offline
post #407 of 551 Old 04-17-2012, 09:47 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Make sure you take plenty of pictures on this part, I'm doing it in a few weeks.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #408 of 551 Old 04-17-2012, 03:36 PM Thread Starter
bbc
It's Official! The Harness and ECM has been Ordered through PSI Conversions. The only major difference I had to make was ditching the Drive By Wire and going to a Drive by cable set up with a new billet Throttle body from edelbrock. And going back to the CJ Pedal. Reason being is, They only made the LS2 with the 24X reluctor for two years and nobody really makes a harness that supports the E40 ECM. So, going to a 90mm Drive by cable set up and a LS1 ECM was a must. Or I would have had to find a Pedal and Tach Module from a C5 vette to keep the Drive by wire, and those are out of production and expensive and would cost more than the new edelbrock throttle body.
bbc is offline
post #409 of 551 Old 04-17-2012, 03:43 PM
Skerr
Glad you know what you are doing. I couldn't save my family if I had to give some info about your system!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #410 of 551 Old 04-17-2012, 05:36 PM Thread Starter
bbc
It's not that bad, But then again it ain't running yet.
bbc is offline
post #411 of 551 Old 04-22-2012, 06:06 PM Thread Starter
bbc
got a little bit more work done on the dash. Still waiting on a tach, and speedo. I was bummed out about not being Abel to use that sweet looking GTO pedal, So now that I have to use the CJ pedal I decided to trick it out too. I also have a matching brake pedal.
bbc is offline
post #412 of 551 Old 04-22-2012, 06:53 PM
Skerr
That is just cool. Details!!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #413 of 551 Old 04-22-2012, 07:09 PM Thread Starter
bbc
The gauges? or the pedals?
The pedals I found on E-bay, They said they were for a YJ/TJ. The accelerator pedal comes with a little bit of a concave to it. So, you have to bend it straight. Set it over the plastic pedal and drill 3 holes. 1of the holes, you will need to trim a little bit of plastic away to get the provided washer and nut on and get it to tighten down flat.
Gauges, are Auto meter Ultra-lites. I have the 180 MPH Electronic Speedo on the way as well as a 8000 RPM Tach. I will have to do some sort of a plate attached to the back of the old speedo hole as it's only 5" not sure if I will have to modify the tach hole yet.
bbc is offline
post #414 of 551 Old 04-22-2012, 07:13 PM
Jim1611
Jim1611's Avatar
I'd rather have the cable for the gas and as far as I'm concerned it'll be better in the long run. Hurry so we can hear about this thing running or are you about to take another vacation again.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #415 of 551 Old 04-22-2012, 07:25 PM Thread Starter
bbc
It's not called Vacation, It's called Marriage Maintenance! We all know we need that!
The harness should show up next week. I hope.
I also have a dual fan harness coming to run the fans in a parellel/series set up. I will have 2 wires coming from the ECU, 1 for high, 1 for low fan speeds triggered by pre programmed temps in the ECU. The fist wire will trigger both fans to run at 6 volts or half speed. And if needed the second wire will trigger them to run at the full 12 volts or full speed.
bbc is offline
post #416 of 551 Old 04-22-2012, 07:33 PM
Jim1611
Jim1611's Avatar
So true my friend. But I do need something to rib you about.
My build thread
Jim1611 is offline
post #417 of 551 Old 04-22-2012, 07:35 PM Thread Starter
bbc
Here's both pedals-
bbc is offline
post #418 of 551 Old 04-22-2012, 08:06 PM
REDnBLUES
1977 CJ7
I really like your gauge setup. Did you have to re-engineer your defroster duct to get those to fit?
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #419 of 551 Old 04-22-2012, 08:48 PM Thread Starter
bbc
I was looking at that the other day. But I forgot about it. I'm not sure yet. I'll get back to you on that. I'll make it work some how.
Update- Upon further review, You are right.
I'm going to have to modify the duct. If I can't heat it up with my heat gun and squish it in a bit. Then this is something I found searching a bit. I might have to consider this.
bbc is offline
post #420 of 551 Old 04-23-2012, 06:48 AM
REDnBLUES
1977 CJ7
You know, that looks like a better setup than the factory anyway...no paper ducting.
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
