Project "Envy" - Page 26 - JeepForum.com
post #376 of 551 Old 03-27-2012, 04:13 PM
Coiz
1979 CJ7
Nice, I prefer a bikini top over all others.
And yes, it is the pink wire for the sender.
Mike
Coiz is offline
post #377 of 551 Old 03-27-2012, 04:18 PM Thread Starter
bbc
Yes, Pink Wire. I'm Waiting on some new Rollover valves for the tank. And then it's going back in.
bbc is offline
post #378 of 551 Old 03-31-2012, 12:32 PM Thread Starter
bbc
Fuel system is complete.
Tank is in and all fuel lines ran.
I went with rubber EFI hose from the sender to the Corvette filter/regulator and stainless from there to the fuel rail.
The lines coming out of the filter/regulator had to be reduced to hook up with the sending unit.
-Sending unit feed is 5/16 and return is 1/4.
-The Corvette filter/regulator inlet is 3/8 and return is 5/16.
- Then 3/8 stainless to fuel rail.
And here is a picture of the reducers, got them from Jegs. 3/8-5/16 &. 5/16-1/4
bbc is offline
post #379 of 551 Old 03-31-2012, 04:44 PM
Jim1611
Jim1611's Avatar
So when's it getting cranked over?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #380 of 551 Old 03-31-2012, 06:12 PM
jhughes2013
1977 CJ7
Watch out. When she fires she'll scare the hell out of you...
'77 CJ7, LS1, NV4500/D300, Ford 8.8, 4" of lift, 33x12.50 BFG ATs...
jhughes2013 is offline
post #381 of 551 Old 03-31-2012, 07:00 PM Thread Starter
bbc
Well,
I just need to get a PCM & Stand Alone Harness and it should be Abel to make some noise.
I have been spending a lot of time double checking everything and making sure everything is tight.
Here is a tip for re assembly - After you tighten or torque a bolt, put a dot of finger nail polish (color of you choice) on the head to indicate its tight, Torqued, or checked. That way you won't keep wondering.
bbc is offline
post #382 of 551 Old 03-31-2012, 08:17 PM
Skerr
Good idea about marking the bolts, but I need to remember not to put stuff on upside down! C'mon, Shaun. Let's see another picture of the Jeep!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #383 of 551 Old 03-31-2012, 08:26 PM
FamousJerry
2014 JK Wrangler
More engine photos!!!! oh and nice color i have an 85 the same color :-)
FamousJerry is offline
post #384 of 551 Old 04-02-2012, 12:57 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Originally Posted by bbc View Post
Well,
Here is a tip for re assembly - After you tighten or torque a bolt, put a dot of finger nail polish (color of you choice) on the head to indicate its been tighten, Torqued, or checked. That way you won't keep wondering.
Very smart man, Navy uses stuff called Torque Stripe, apparently it's cheap. It's basically just like a colored elmers glue, when it dries it's pretty solid. Works wonders for all the vibrations on our helicopters.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #385 of 551 Old 04-06-2012, 03:24 PM Thread Starter
bbc
Removed my dash again to do some much needed repairs. The volt gauge needle was broke and the oil gauge acted a little funny from what I can remember. And some of the lights were out.
I want to be Abel to read the LS2's Vital signs before I start it up, So off the dash came.
bbc is offline
post #386 of 551 Old 04-06-2012, 03:26 PM Thread Starter
bbc
I found a new volt and oil gauge, And decided to clean up the gauges a little bit with a new look.
I still need to do the Tach gauge and put the oil and volt gauge back together.
bbc is offline
post #387 of 551 Old 04-06-2012, 03:28 PM Thread Starter
bbc
I need to change some lights out because some where burnt out, So I decided to go with all LED's
bbc is offline
post #388 of 551 Old 04-06-2012, 03:34 PM Thread Starter
bbc
I Also want to change the color that the gauges are backlit with from the blue to Red.
For this I removed the blue bulb covers from the gauges. And for the indicator lights I wiped the blue film off of the backs of the plastic screens with a little help from my wife's nail polish remover. I will then color with a Red Sharpie
image-1726299606.jpg   image-2803584691.jpg   image-595640814.jpg   image-2026208935.jpg
bbc is offline
post #389 of 551 Old 04-06-2012, 03:42 PM Thread Starter
bbc
I wanted to Remove the old dash overlay Around the gauges because it was cracked. I thought maybe I could go without it for a cleaner look. But the Previous Owner decides to hack up the dash to fit a radio, So that's not going to happen. I ordered a new overlay to hide his hack job.
bbc is offline
post #390 of 551 Old 04-06-2012, 03:47 PM Thread Starter
bbc
I finished up the wiring of the old harness with the Neutral safety switch and back-up switch.
The loose yellow wire on top in the first pic. is for the 4WD indicator light when I get the transfer case all buttoned up.
bbc is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
