Project "Envy" - Page 23 - JeepForum.com
post #331 of 551 Old 12-29-2011, 07:10 PM Thread Starter
bbc
Originally Posted by Skerr
Shaun... what do you do for a living?? I think I remember something in the auto industry, but I don't remember? I wish I "knew what to do" with "things"! You are very good at it.
I went to Tech School for Auto Mechanics, But, Found myself being a Tile & Stone Contractor. And who ever said I knew what I was Doing? Ha Ha Ha.
I spend a lot of time on the net researching
what works and what doesn't.
bbc is offline
post #332 of 551 Old 12-30-2011, 08:17 PM Thread Starter
bbc
Before I put the dash all back together after the YJ Brake pedal swap, I decided to do the heater blower motor upgrade.
For those of you that don't already know. Get a blower motor for a 73' Blazer with a 350 And (No AC). Open up the hole in the fire wall a bit and it bolts right up.
I also put in a new Heater core while I was at it. I figured the old one is 25 years old and I don't want to do all this twice down the road if it started to leak.
Hear is a picture of the new heater core in place and the heater box getting a bead of black silicone to get sealed back up.
bbc is offline
post #333 of 551 Old 12-31-2011, 07:49 PM Thread Starter
bbc
Happy New Year Wishes To All
bbc is offline
post #334 of 551 Old 01-12-2012, 06:42 PM Thread Starter
bbc
Been working on things here and there in the Jeep. I got the dash all put back together from the heater motor upgrade. Here is a picture of it from the Engine compartment. It's a tight fit against the bottom of the battery tray, But it fit.
bbc is offline
post #335 of 551 Old 01-12-2012, 06:45 PM Thread Starter
bbc
Got the CJ oil pressure sender and switch adapted to the LS2. And the Second picture is where the water temp sensor will go in the back of the right side head.
bbc is offline
post #336 of 551 Old 01-12-2012, 06:48 PM Thread Starter
bbc
The Modified Steering pump and Res. came from PSC. The Res. has a second return on it for a return from the Hydroboost
bbc is offline
post #337 of 551 Old 01-12-2012, 06:49 PM Thread Starter
bbc
Hoses and Fittings starting to show up.
bbc is offline
post #338 of 551 Old 01-12-2012, 06:56 PM
Skerr
I'm a-watchin'! Lots of great parts, Shaun.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #339 of 551 Old 01-13-2012, 08:16 PM Thread Starter
bbc
I was hoping the rest of the fittings I needed would show up today, So I could run all the plumbing this weekend. But no dice. I did finish up a bracket I was working on to mount the steering Res. to the front of the engine though. Check it out!
bbc is offline
post #340 of 551 Old 01-20-2012, 08:06 PM Thread Starter
bbc
The Lokar Shifter came for the 4L60E.
I got it to mount in the floor where the old 5 speed shifter lever came out.
Most of the Plumbing has been run, I just need a little more hose to run One more Tranny line to the cooler. And then it will be on to the Fuel System.
bbc is offline
post #341 of 551 Old 01-21-2012, 12:41 PM Thread Starter
bbc
Here is a few pictures of all the plumbing
bbc is offline
post #342 of 551 Old 01-21-2012, 12:45 PM
Coiz
1979 CJ7
Looking good for sure!
Mike
Coiz is offline
post #343 of 551 Old 01-21-2012, 03:15 PM
John87
first i would like to say awesome thread!
the research i did says to use a blower motor WITH AC, could you elaborate?
-John
°llllll° 1985 CJ-7
John87 is offline
post #344 of 551 Old 01-21-2012, 04:18 PM Thread Starter
bbc
I first tried one from one with AC, because I too read the same thing. The shaft you mount the fan to is too long. The One without AC is the exact same length shaft as the one I was replacing. You will know if you have the wrong one. Hope that helps.
bbc is offline
post #345 of 551 Old 01-21-2012, 04:45 PM
John87
it does. i will be sure to keep this in mind when i go to buy mine. thanks!
-John
°llllll° 1985 CJ-7
John87 is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
