Project "Envy" - Page 11 - JeepForum.com
post #151 of 551 Old 05-17-2011, 02:52 PM
kakai81
Did you have to reuse the original metal inserts or did it come with new ones?
"Remember when parking lot wheeling never wheel alone!!" -Found on the TJ forum in reference to a guy who got stuck on a pile of snow.
kakai81 is offline
post #152 of 551 Old 05-17-2011, 04:02 PM
benullman
1981 CJ7
Originally Posted by bbc View Post
Hurry up? This things on the 5 year plan as I have a budget each month on the jeep set by my wife. Might have to move the jeep to a new location, so yes- I did order a body mount kit to put the tub back on for now. I will put the tub on outside so it won't be stuck in rather it might be stuck out.
Also ordered steering stuff to complete the front end. Needed to go complete high steer.
Sweet looking build man! Love the tire combo!
Remember if you mount the body you can just leave the roll bar off while you are finishing it up, then it will fit in!
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #153 of 551 Old 05-17-2011, 04:10 PM
243
1978 FSJ Cherokee
It looks like a total BEAST in this picture!!!
Dave's 78 Build
243 is offline
post #154 of 551 Old 05-17-2011, 09:21 PM Thread Starter
bbc
I don't think it comes with inserts. And the new T-style inserts are like $4-$5 each. I think what I will do is get some sleeves from the local hardware. The kit has not come in yet, they sent me an email today saying they are out of stock and expect more in 2 weeks. I'll let you know what I come up with
bbc is offline
post #155 of 551 Old 05-17-2011, 09:25 PM Thread Starter
bbc
Yep, it ended up bigger than I thought. It does look Cool though. It should come down a bit with the weight of the tub and engine.
bbc is offline
post #156 of 551 Old 05-22-2011, 11:45 PM Thread Starter
bbc
Parts should be arriving this week to get the front steering straightened out.
When I first started the 44 build I got the passenger knuckle milled/taped and had planned on keeping it SUA. And just running the drag link only above the spring with a single high steer arm on the passenger side. Well, things changed.
Now, with going SOA I want To go with a full high steer setup, So instead of having to ship off the drivers side knuckle to get milled and taped. I ordered a set of Reid Armless knuckles. I will also need to get a different set of high steer arms that have a
double hole on the passenger side and be taller to make it over the springs.
I also noticed that I got a little too much positive camber. As my front wheels look like this \ jeep /
I figure I will straighten this out with some degree shims behind the spindles when I put the new knuckles on.
I have a lot of parts that still need paint and need to get to it soon as they are starting to surface rust on me. I guess I will just get more use out of the blasting cabinet.
Pictures and updates as the parts arrive-
bbc is offline
post #157 of 551 Old 05-24-2011, 06:05 PM Thread Starter
bbc
this is how the stock daystar bushings look. it does have a metal sleeve on the outside. the instructions don't say anything about reusing the original T- style inserts.
bbc is offline
post #158 of 551 Old 05-24-2011, 06:08 PM Thread Starter
bbc
here is the daystar sway bar bushing kit
bbc is offline
post #159 of 551 Old 05-24-2011, 06:28 PM Thread Starter
bbc
stainless body mounting bolts from the local hardware $24
bbc is offline
post #160 of 551 Old 05-24-2011, 06:33 PM Thread Starter
bbc
JKS quicker sway bar disconnects. I like that these ones are adjustable for length. Now I just have to blast and paint the old sway bar and weld on some tabs to the axle.
bbc is offline
post #161 of 551 Old 05-24-2011, 06:41 PM
benullman
1981 CJ7
I would rethink this. Im sure Stainless MIGHT be ok but I would want the strongest bolts holding the body to the frame.
Go grade 8 with some anti sieze and locktite and you wont have an issue.
just my .02
Ben
post #162 of 551 Old 05-25-2011, 12:16 PM
kakai81
Stainless has a higher tensile strength than grade 8.
kakai81 is offline
post #163 of 551 Old 05-25-2011, 12:26 PM
mtbtweety
mtbtweety's Avatar
1982 CJ8
not usually, especially the stainless you buy in hardware stores. You can get it that way, however.
http://www.totallystainless.com/totallystainless.htm
mtbtweety is offline
post #164 of 551 Old 05-25-2011, 01:51 PM
kakai81
You're right, hardware store stainless is not the strongest. However, stainless from a reputable fastener place will be stronger than grade 8. Try Fastenal, they always treat me right.
kakai81 is offline
post #165 of 551 Old 05-25-2011, 01:55 PM
benullman
1981 CJ7
oh I didnt mean to make a blanket statment because you can get alot of different grades. But generally stainless seems to be made to about Grade 5 standards
Ben
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
