Quantcast Project "Cage" - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Project "Cage"
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 08-14-2007, 09:07 PM   #1
Fatman
2008 CJ7
Project "Cage"
Ok, so the tub posts (on my part) are going to take a vacation.
We have to fit up a few things before the tub comes back off.
Ordered a Kentrol Inc. Sport Cage. The kit came with L & R floor plates, the front sport bar 0.125, and a pair of pre-bent "kicker" tubes also 0.125. As well as some instructions.
So we put the bar in moved it around and decided on 3/4" off the windshield
Oh, we put the windshield frame in place and cleaned up the old brackets, I have new black stainless everything waiting for the after paint party. Also installed the stock "show" bar
Added some oak plank to keep the gap equal, checked the angle on both sides and marked the floor.
Placed the plates and found the pre formed plate angles needed about 7* more, so some massaging with the press and we have a nice fit
Cleaned up the plates, and measured up the bar for the needed cuts, leveled, measured, repeat, repeat, repeat, ..... cut!
BTW, I'll just show one side as the left and right work is almost the same thing. Just remember to line up the tube based on the body location, not the plate location.
Left:
Right:
Fooled ya!
Next we measured out the tube for the dash bar. Super Friend let me borrow this awesome tool:
Dash bar held in by compression, need to put in old dash and cut the dash pad to check height
More pics and details to follow shortly
Fatman is offline   Reply With Quote
Old 08-14-2007, 10:14 PM   #2
1979CJ7
1979 CJ7
looki good man. cant wait to tsee the rest... where did you buddy get that notcher from>
1979CJ7 is offline   Reply With Quote
Old 08-15-2007, 07:51 AM   #3
Fatman
2008 CJ7
To bring this up to date,
After putting on the old dash panel, we cut the dash pad with a sawsall and used a belt sander to shape the sides of the pad:
put some JB Weld on the drivers end where it became a little frayed:
I'm looking for a product that I can paint on or dip the pad in to get a nice simi-hard finish over the foam again.
Pad installed and dash bar height adjusted
Put the seats in so we could check the fit of the diagonal lateral bar
Me and my son. First time we have sat in the Jeep since November
We bent two bars out of 2" 0.225 to match the ones that came with the kit. We'll install those shortly along with the lateral and a few grab bars.
Of course the lateral goes behind the seat but you get the idea.
Random shots:
Will stop this afternoon and pick up the 3/16" for the front and center frame tie in's. Need to order some isolators for the rear tie ins and cut out the rear quarter panel supports
Old 08-15-2007, 09:01 AM   #4
JoonHoss
1968 C101
this has been a very rewarding project...
Originally Posted by Fatmans Son
this jeep will get me SOOOO many chicks...
for your dash pad- you might try contacting a place like this:
http://www.creativecolorsintl.com/
hth
Keep up the good work!
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Old 08-16-2007, 07:02 AM   #5
Fatman
2008 CJ7
It's a Northern Industries product, I guess that means Northern tool?
Old 08-16-2007, 07:43 AM   #6
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
quick search yielded...
http://www.amazon.com/Northern-Industrial-Tools-Tubing-Notcher/dp/B0000AX6PN
cb
CertifiableJeep website
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
ORANGE JEEP CLUB #41
certifiablejeep is offline   Reply With Quote
Old 08-16-2007, 04:44 PM   #7
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Might try brushing or spraying on several coats of Plasti-Dip on those exposed ends. I've dipped rope ends into the stuff and built it up to a pretty thick coating to keep the rope from unravelling.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 08-16-2007, 04:48 PM   #8
bulljeeper
i really the jeep so far. the rollbar is a nice touch. i just hope it doesnt have to come in handy.
oh yeah, i hate all of you who have shops, garages, and even carports!
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
lOd Rear Tire Carrier
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
Spyder Customs Crusher Corners
http://www.cardomain.com/ride/2527972/1
bulljeeper is offline   Reply With Quote
Old 08-17-2007, 06:06 AM   #9
84MSRB
Pretty cool looking stuff so far. We are definitely not doing things in the same order though.
Does that upper radius on the front bar bother you at all? I never really saw one from the angle you showed, and it looks like it takes out a decent chunk of your windshield- not that the upper corners will let you see much other than incoming aircraft, I guess.
1984 CJ7 Mud Slingin Rust Bucket
90 YJ tub
Ford Mutt 5.0( 69 block, 89 EFI)
84MSRB is offline   Reply With Quote
Old 08-17-2007, 08:34 AM   #10
Fatman
2008 CJ7
It's not so bad, lil bit-o trade off
Old 08-18-2007, 07:32 AM   #11
Axehandle
Good Stuff... I need to do the same on my CJ5. Might entice my wife to ride in it. How bad was the shipping on that front roll bar?
Axehandle is offline   Reply With Quote
Old 08-19-2007, 02:00 PM   #12
Fatman
2008 CJ7
Well I was not able to pick up any steel Friday so I just did some small tasks to get ready for the frame tie-ins.
Cut up the last of my 3/16 plate.
Drivers front plate:
Drivers center, drilled out and ground off the old tie in nuts:
Plate is not enough, frame is going to hang up on the tub lip. Made isolators:
One plate was not enough to get out from the lip, used the right side plate I cut and looks like we're there.
Went back and put isolators under the front tie-ins:
Patterns are cut for the frame tie ins, will cut & install in the next few days.
Old 08-19-2007, 07:14 PM   #13
RnEmOvr
Never Forget
RnEmOvr's Avatar
looking good, cant wait to see the end of this one too,
also why did you prime over your jeep sticker?
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 08-25-2007, 09:33 AM   #14
Fatman
2008 CJ7
Lil teaser !
Plan on getting all the tube tacked today.
Cut all of my frame tie in plate from 1/4"
Going to do a link type setup for the rear tie in
more to come.
Old 08-25-2007, 09:41 AM   #15
jatepper
jatepper's Avatar
Looks good fatman. Looks like you two are having a good time with the rebuild. It seems like you guys have everything you need to do the job right.
Do you guys have any room for a foster adult to come and stay for a while?
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Torchmate CNC Plasma Table Build / Projects
Handen Fabrication
jatepper is offline   Reply With Quote
Glock Forum
