Project advice - JeepForum.com
post #1 of 3 Old 11-15-2013, 12:08 PM Thread Starter
atlshaun
1983 CJ8
Project advice
Specs:
1983 Scrambler
Original 258 with 124k miles
BBD Carb
T5 Transmission
AMC 20 Rear / Dana 30 Front
I will post pics this weekend.
I bought it a few weeks back from the SW USA and it arrived 2 weeks ago. I have an '83 Scrambler with minimal to no rust. The tub has some surface rust and that will be the first thing I will want to take care of.
I sold the original wheels and tires that were on it and replaced them with MT Sidebiters (See my other thread for that debacle) and 33's. Now that those have been machined and fit perfectly I want to begin on my project.
My plan is to remove the tub and treat the underside to prevent it from rusting. While I have the tub off I am going to treat the frame, inside and out to do my best to withstand the rust there too.
The PO had installed a 4” Rough Country Lift and I have already bought a 4.5” Rubicon Express Lift with Monotube shocks to replace it. It’s sitting next to the Jeep as I type this.
My ultimate goal is to do ALL of the following, and I would like help organizing the order in which I do it and any other recommendations for additional items to attend to during the process.
Replace the Rough Country Suspension with the RE
Remove the tub and apply undercoating
Treat the frame, inside and out and also paint the axles
Treat the tub surface rust and then Line-X the inside of the Tub
Paint the Exterior (My plan is to do this at the very end)
Replace the BBD, it stalls at every single stop – with a Motorcraft 2150 kit from ebay
Team Rush Upgrade
Nutter bypass and removal of excess wires
Fix the issue with the Jeep shaking to pieces when starting in first gear
Upgrade to 1 piece Axles on the AMC 20
Regear the AMC 20 (Currently has 3.31’s) to 3.9 or 4.1
Potentially install a painless wiring kit
Replace differential fluids
Replace Dash Pad
Upgrade Brakes?
A/C install / upgrade
New half top and bulkhead
My budget is $15k
What say you?
atlshaun is offline
post #2 of 3 Old 11-15-2013, 12:27 PM
mike_bfdr
1981 CJ8
what r u planning on doing with the jeep?
MY BUILD-----> http://www.jeepforum.com/forum/f22/81-jeep-scrambler-3-link-1507615/
mike_bfdr is offline
post #3 of 3 Old 11-15-2013, 12:44 PM Thread Starter
atlshaun
1983 CJ8
Besides making sure I can keep it viable for the rest of my life...
60% on road driving and must be capable of interstate travel as I will use it 20% for hunting within a 3 hour radius of my home and 20% off road fun....none of which will require me to "rock crawl"...mostly light to mid level trail riding
atlshaun is offline
