Project 23's Paint - Page 8 - JeepForum.com
post #106 of 953 Old 04-22-2012, 07:26 AM
gazzo
Sorry mate. Rust.
gazzo is offline
post #107 of 953 Old 04-23-2012, 07:07 AM Thread Starter
PROJECT 23
Going to attempt to remove the current roll bar to make room for the YJ family bar. Any tips or tricks I should know about prior to starting this? I really need to get this out since the family bar is taking up space in the new garage (specifically my wife's parking spot)
PROJECT 23 is offline
post #108 of 953 Old 04-23-2012, 07:18 AM Thread Starter
PROJECT 23
Originally Posted by Matt1981CJ7
You realize you'll have to clean up that brake master and booster before you show off the finish product.
Just watchin' your back.....
Matt
That's easy to hide. Once I get the hood back on nobody will ever know ; )
post #109 of 953 Old 04-23-2012, 07:22 AM
lucdog
lucdog's Avatar
1980 CJ5
A helper to lift it out. And blankets to protect the paint!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #110 of 953 Old 04-23-2012, 08:19 AM
chopki1
1981 CJ7
I did the same swap and I had to remove most of the torx bolts with my 4 1/2 inch "wrench". Once the factory bar was out I found the floor pretty much gone under all four mounting points due to rust. Fairly easy and straight forward fix though, cut,patch,prime,paint. Then sit your new bar in place and mark and drill your new holes,bolt it up and your done. I would recommend adding some backing plates on the under side at the least. And even better would be to go ahead and tie into the frame. Nice job so far its looking good.
chopki1 is offline
post #111 of 953 Old 04-23-2012, 08:24 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Steve,
If your roll bar is anything like mine, expect to twist the torx heads off about half of the mounting bolts. You'll get to know the drill/extract/re-tap technique well.
Also, expect to see some rust under the mounting plates, especially the ones on the floor. AMC chose to install the roll bars before the tub was painted, so there's bare metal under those plates.
In hindsight, I wish I had noticed that you didn't pull the roll bar before painting. I would have suggested you do so.
Matt
Matt1981CJ7 is offline
post #112 of 953 Old 04-23-2012, 08:24 AM Thread Starter
PROJECT 23
My understanding is that the family bar should mount with the existing mounting holes from the stock bar. I shouldn't have to drill new holes. If I do need to drill new holes, I will have a family bar listed in the classifieds because I'm not drilling additional holes into my tub.
post #113 of 953 Old 04-23-2012, 08:28 AM Thread Starter
PROJECT 23
There is a "soft spot" behind the passenger side front roll bar mount. I am expecting worse case scenario and I have my welder buddy on standby to work his magic. Hopefully the rust and rot didn't make it's way under the roll bar mounts. Other than that we should be in good shape.
post #114 of 953 Old 04-23-2012, 08:29 AM
Matt1981CJ7
1981 CJ7
Umm, that's your call. What I was talking about are the existing torx bolts that are holding the factory bar on. Most of those are probably rusted stuck. I twisted four of the torx heads off of mine. Those required drilling the old broken bolt out, then re-tapping the holes.
Matt
post #115 of 953 Old 04-23-2012, 08:35 AM Thread Starter
PROJECT 23
Matt
Matt,
I totally understand that some drilling and tapping will take place. What I was asking is does the existing mounting holes from the stock bar line up with the family bar mounting holes? I want to utilize the stock mounting holes to install the family bar.
post #116 of 953 Old 04-23-2012, 08:35 AM
Matt1981CJ7
1981 CJ7
I can't answer the bolt pattern question, but I bet a little searching would.
I don't know if you saw my tub repair thread, but this is what mine looked like under the roll bars, and then the subsequent repairs.
Good luck, and let us know what you find.
Matt
RollParPatch1.jpg   RollBarPatch2.jpg   RollBarPatch3.jpg   RollBarPatch4.jpg   PaintFinal6.jpg
post #117 of 953 Old 04-23-2012, 08:38 AM
chopki1
1981 CJ7
The reason I said drill new holes is in my case I ran into rust under the mounting points. So the original mounting bolt holes got cut out and replaced with a blank piece of sheetmetal. Therefore I had to drill all new holes. It really wasn't that bad I would say total job from start to finish including removing the old bar,cutting out and patching the sheet metal,dropping in the new bar and drilling holes,bolting it up probably took me 5 hours total. And thats with no help. If you run into rust (good possibility) you will find it worth the trouble to remove and repair it. Here is a link to my thread. I covered my rollbar swap on the very first page. http://www.jeepforum.com/forum/f8/my-1981-cj7-1263545/
chopki1 is offline
post #118 of 953 Old 04-23-2012, 08:45 AM
chopki1
1981 CJ7
It looks like me and Matt went down pretty much the same road. If you run into the same issues we did which are very common. You will need to cut out and replace. If you are lucky enough to have no rust then yes I'm pretty sure all but 1 bolt hole will line up on the yj bar. The one that doesn't line up isn't off by much from what I understand. From what I read during my swap all you would have to do is wallow out one of the holes in the bar mounting foot to make it work.
chopki1 is offline
post #119 of 953 Old 04-27-2012, 05:52 AM Thread Starter
PROJECT 23
FINALLY!!! I will have some time to work on Project 23 as the wife is working 2-10 PM on Saturday. First up is removing the old roll bar. Hopefully that will go fairly well. If it turns out to be a disaster I will change my focus to getting the hood, tailgate, windshield frame, windshield installed. That way it will at least look like a Jeep again.
I have all the neighbors wondering what's under the cover in the garage. We just moved in and just about everybody that walks by asks what I'm hiding. I tell them that they'll find out in due time. Maybe I'll throw on some Cherry Bombs when I finally fire her up for the first time. That should get their attention
Progress pictures to come this weekend......
post #120 of 953 Old 04-27-2012, 06:03 AM
Matt1981CJ7
1981 CJ7
Dude, you don't have that thing back together, yet? What's the hold up?
If you're pressed for time, I'd definitely start with the body, and skip the roll bar, for now. If your roll bar is like mine, it's going to take the better part of a 1/2-day to get it off. Save that for when you're not rushed.
I think you'll be surprised how quickly the rest of it goes together.
Matt
