Procomp lift question. CJ5 1980 - JeepForum.com
post #1 of 5 Old 05-04-2012, 04:34 PM Thread Starter
RustyBoltCJ
1980 CJ5
For all of you have messed with your suspension i have a question. my leaf to frame bushings seem to not have full contact. the mount looks like its bending in to touch the bushing as well. just wondering if i should throw a washer in between there. take a look for your self.
http://s1243.photobucket.com/albums/...t=DSCN2115.jpg
http://s1243.photobucket.com/albums/...t=DSCN2116.jpg
RustyBoltCJ is offline
post #2 of 5 Old 05-04-2012, 05:08 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Did you install the metal sleeve ?
LT1CJ7 is offline
post #3 of 5 Old 05-04-2012, 05:12 PM
Outnumbered
Would not hurt to shim with a washer. May be hard to get one in there though. Looks fairly tight to me. With leaf spring suspension and no track bars you are going to get some lateral movement in the springs and it gets worse the higher the lift and skinnier the leaf (2' CJ vs 2-1/2" YJ). That is another reason why I plan to up grade to YJ springs in the future. Anyway, I think you will be OK either with or without the washer. Other than the obvious (replace all loose and worn suspension and steering parts), make sure your caster is positive about 6-8* and you will have a much more manageable jeep.
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline
post #4 of 5 Old 05-04-2012, 05:18 PM Thread Starter
RustyBoltCJ
1980 CJ5
Thank you so much. LT1CJ7 yes it came with the sleeve in already. Outnumbered- I was able to bend the mount out a bit with a bolt and was able to get the washer in there. looks nice and flush now.
post #5 of 5 Old 05-04-2012, 06:36 PM
Outnumbered
Cool
cj5 , leaf spring , leaf springs , pro comp lift kit , problem
1980 CJ5 Lift Question BBOW Jeep CJ Forum 3 10-22-2010 08:30 AM
1980 CJ 5 Lift Kit SCHUSKER Jeep CJ Forum 6 12-26-2009 12:04 AM
Procomp Lift Probs ollietonk Jeep CJ Forum 0 03-12-2004 07:42 AM
Is there a 6 inch lift out there, for a cj 7 1980? What is the best overall lift? jeepcj7 Jeep CJ Forum 13 01-18-2003 09:46 AM
What is a better lift procomp or superlift?? JeepTrickz Jeep CJ Forum 3 08-30-2001 10:06 PM
