Procomp Lift Probs - JeepForum.com
post #1 of 1 Old 03-12-2004, 08:42 AM Thread Starter
ollietonk
Procomp Lift Probs
I just installed a 4 inch Procomp suspension lift on an 86 CJ7. Now I'm having problems with the stock shackels sitting right. 3 of them sit at almost 90 degrees and look OK. The front drivers side is laying back, flat against the frame. I checked the measurments when I put the new springs on and everything checked out fine. I've tried loosening the bolts on the shackel, take the weight off the Jeep, then set it down again but the shackel keeps goning overcenter. My theories range from the stock shackels are too short, to the actual spring is too short.
Has anyone else had this problem?
Also, with the 4 inch lift, am I going to need to lengthen the driveshafts? Thanks for any input.
ollietonk is offline
86 CJ7 carb probs Michael_94YJ Jeep CJ Forum 7 02-02-2008 07:58 PM
volt probs? moach1 Jeep CJ Forum 2 10-06-2006 09:57 PM
3 Probs; and 0 clues Kevmatic Jeep CJ Forum 6 07-03-2006 08:55 PM
4.2 having idle probs Comanche5L Jeep CJ Forum 6 05-22-2006 01:43 PM
What is a better lift procomp or superlift?? JeepTrickz Jeep CJ Forum 3 08-30-2001 11:06 PM
