Problems with Tub Swap - JeepForum.com
post #1 of 6 Old 02-26-2002, 07:54 PM Thread Starter
TG CJ7
Post Problems with Tub Swap
My brother and I just replaced his rusty CJ tub with a YJ tub and now we can't seem to get it to start. See he took the body one day when I wasnt there and didn't lable anything, I think he was just exited about the new tub. The Jeep will turn over but we're not getting any spark. The body mounts arent bolted down tight yet, so maybe its not getting ground?? Or we messed up plugging everything back in, I dont know. Im not very good with the electrical stuff, so if there is a messed up connection some where, where is the first place to look first?? Hes got an 84 CJ7 with the 258. Its going to get warm here in a couple weeks and I think he'd like to get it going.
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #2 of 6 Old 03-05-2002, 08:59 AM
NC74CJ
NC74CJ's Avatar
Post
Got it running yet? If not, check for power at the coil. Grab a test light and use it to determine if you have a grounding problem, a hot wire problem, or both. If you are getting power then its a distributor problem. If his wireing remained intact then it sounds more like a grounding problem to me. Good Luck!
Bill
A stroke bolder, a pinch better.
NC74CJ is offline
post #3 of 6 Old 03-05-2002, 01:19 PM Thread Starter
TG CJ7
Post
I still havent got to run yet. I took the coil out of my 84 and tried it on his; it still didnt work so it must not be the coil. It ran fine when he took it apart so it must be something that we did. I havent really gotten a chance to mess with it much, we've got other issues to worry about right now. Im still looking for the grommet to a line that runs into the gas tank, so the tanks not on yet. I guess once I get the gas tank ready to go I'll tighten down the body mounts and see if that does anything (which I dont think it will). Then I guess I'll just start testing lines like you said. I'll need to take a good hard look at it.
Does anyone know where I could find this grommet? Its a rubber piece for what I guess is a rollover protection line that runs into the tank. The dealer says they dont make them anymore. I know it not on 82 and older jeeps. We are thinking of just pluging it up. Would there be any problems with that?
Thanks for the help.
Check it out
TG CJ7 is offline
post #4 of 6 Old 03-05-2002, 09:33 PM
NC74CJ
NC74CJ's Avatar
Post
i would definately do it the way it was designed.... check out lowes they have tons of grommets in all sizes. you can also find some at the local autoparts store under the help section with pcv stuff. good luck
Bill
NC74CJ is offline
post #5 of 6 Old 03-05-2002, 10:35 PM
HighCountry
Post
Look on the passenger side of the engine above the oil pressure sending unit. there is a bolt there attaching a wire to the engine. I know that my 86 CJ will NOT fire if that small wire is disconnected. If it is not connected, it should be hanging around there somewhere close and it has a large "ring terminal" that fits the bolt in case you are looking for it.
Bruce
HighCountry is offline
post #6 of 6 Old 03-06-2002, 07:13 AM
twmattox
Post
Check your fuses first. Mine does just what you describe when it blows the fuse for "Indicator lamps". On mine it is the fuse on the lower right of the fuse block. If I can follow the diagram it feeds into the coil. Hope the fix is as easy as this...
twmattox is offline
Tub swap/steering problems kpmunt Jeep CJ Forum 0 12-07-2009 11:07 AM
Problems with a 304 swap, 79 CJ7 red240z Jeep CJ Forum 1 09-15-2009 08:39 AM
HELP!!! T18 swap problems!! rustymudder Jeep CJ Forum 12 08-05-2009 12:02 PM
Problems with a 4.2 to 4.0 swap 93CJ7 Jeep CJ Forum 2 03-23-2007 11:04 PM
Engine swap problems butrfly002 Jeep CJ Forum 3 07-28-2005 04:52 PM
