Problems with power steering pump - JeepForum.com
post #1 of 5 Old 02-18-2010, 06:55 PM Thread Starter
Jeepguy91
Well i am in the process of finishing up my motor swap in my 86 cj7. I am swapping in a 360 v8 out of a 79 j-10. The problem i am having is that when i go to hook up the power steering lines to the back of the 360 power steering pump, the one line that threads in won't fit. Was wondering if anybody else has had this problem and what you did to correct it.
Thanks,
Ben
2000 XJ limited-3" rough country, winch, winch bumper, 31" BFG at's
98 ZJ Limited 5.2- FM 40
Jeepguy91 is offline
post #2 of 5 Old 02-18-2010, 07:22 PM
rishar1
1973 CJ5
I had the same problem. Well that and the hoses were to short I ended up going to the local tractor repair shop and had the hoses custom made to fit.
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #3 of 5 Old 02-18-2010, 09:32 PM
frodin1
1980 CJ7
Yup, just find a local hydraulic shop to make some new lines for you. There's usually a Parker equipment supplier in just about every town.
frodin1 is offline
post #4 of 5 Old 02-19-2010, 10:58 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
There's nothing wrong with the hose/lines. Swap out the fitting on the back of the pump. Use the one from your other pump, or just use your other pump.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #5 of 5 Old 02-19-2010, 11:56 AM
CSP
Do as Pavement Pounder said.
Anything '79 or older uses SAE inverted flare fittings. Anything '80 and newer uses a metric, o-ring type fitting.
The fittings on the back of the pump that the lines attach to just unscrew from the pump itself.
CSP is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Power Steering pump 76CJ5ineburg Jeep CJ Forum 1 01-14-2009 08:53 PM
Power Steering Pump ???? Axe_Em Jeep CJ Forum 1 09-22-2006 08:34 AM
power steering pump ?s rustyCJ Jeep CJ Forum 1 05-08-2006 10:28 AM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 08:18 AM
