Problems with a 304 swap, 79 CJ7 - JeepForum.com
post #1 of 2 Old 09-14-2009, 07:07 PM Thread Starter
red240z
1979 CJ7
I just went back to add the pics, how do I do it?? There is no attachment button.
I bought a 1979 CJ7 258 with a bad rear main bearing with the intent of replacing it with a 304 from a 1982 CJ. I now have both motors and gear boxes out. The pics are attached. The problem is that the splined shafts and the clutch assemblies are completly different. Do I swap out the flywheels? From what I have been told this is an easy exchange. What about the motor mounts? They appear to be the same but do the 304 mounts line up with the 258 holes in the frame on the '79?
The blue 258 in the pics are the old engine from the '79 that I am trying to fit the 304 in. I want to use the gear box and transfercase from the 258 with the 304, its newer and has been recently rebuilt. The U joints appear to be different though.
Any help will be greatly appreciated.
red240z is offline
post #2 of 2 Old 09-15-2009, 08:39 AM
CSP
You didn't attach any pictures, but the splines on the transmission input shaft only engage the clutch. They don't have a thing to do with the engine or flywheel. You may need to change the pilot bushing in the end of the crankshaft, but that would be all that you'd need to change.
Use the clutch plate and pilot bushing that goes with the transmission you're going to use.
CSP is offline
Tub swap/steering problems kpmunt Jeep CJ Forum 0 12-07-2009 11:07 AM
HELP!!! T18 swap problems!! rustymudder Jeep CJ Forum 12 08-05-2009 12:02 PM
Problems with a 4.2 to 4.0 swap 93CJ7 Jeep CJ Forum 2 03-23-2007 11:04 PM
Engine swap problems butrfly002 Jeep CJ Forum 3 07-28-2005 04:52 PM
Problems with Tub Swap TG CJ7 Jeep CJ Forum 5 03-06-2002 07:13 AM
