problems with 258 overheat, etc - JeepForum.com
post #1 of 3 Old 07-16-2003, 10:47 PM Thread Starter
edge1
I just bought this jeep and took it to my mechanic today. new thermostadt, radiator flushed and like new, no leaks worth noting. the engine can idle all day, but overheats quick as soon as the rpms come up. he thinks it may be a cracked block. if it is, should I just order a long block (like from rebuilt-jeep-engines.com) and have someone put it in? What else is involved?I don't know if the engine in it now is original or not. I have a 86 CJ7 with the 258. Please Help!!
edge1 is offline
post #2 of 3 Old 07-17-2003, 12:33 AM
only in a jeep cj
Cracked block, huh... what else is the engine doing....like loss of power? weird noises? etc. Run a compression check across all 6 and check the carb. Too lean of a mix can make an engine run hotter...so I have been told by several mechanics. You can also remove the radiator cap when the engine is cold, start/run it and as the thermostate opens, observe the water flow rate. Also check the timming. and advance.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 3 Old 07-17-2003, 08:05 AM Thread Starter
edge1
no loss of power, no noises, good compression, wate is flowing. not sure about timing or advance.
edge1 is offline
Problems with T90.... andrewferin Jeep CJ Forum 8 11-05-2010 12:00 AM
a few problems Jeepdude84 Jeep CJ Forum 2 09-25-2008 08:17 PM
some problems? 67cj5 Jeep CJ Forum 3 04-28-2008 04:59 PM
v6 problems Mfranks Jeep CJ Forum 4 08-31-2007 09:54 AM
Still having problems... ToxicGreenJeep Jeep CJ Forum 9 02-11-2007 11:41 AM
