Pro Comp SHocks and new leaf springs - JeepForum.com
post #1 of 11 Old 09-06-2012, 04:51 PM Thread Starter
tmholland
1980 CJ5
I just put a 2.5" lift kit and new pro comp shocks and leaf springs on my 1980 CJ5. The ride is a little stiffer than I thought. Will my ride be a little softer after they get broken in?
tmholland is offline
post #2 of 11 Old 09-06-2012, 04:54 PM
benwilde
Imo no. Not if they are pro comp springs. I tried the tuff country for about 2 weeks before I ripped them off and spent the money for a nice set of Rubicon Express springs. Imo you get what you pay for.
benwilde is offline
post #3 of 11 Old 09-06-2012, 05:34 PM
LimeLite
1978 CJ5
Based on my 4" springs, I'd also say no. I took a leaf out of mine to soften it up and improve my shackle angle. The 4" springs are known to be stiff and short, so the shackle tends to invert off road. I don't have any personal knowledge of the 2.5" lifts, but just something to keep in mind.
78 cj-5 4" procrap lift on 35's amc304 "custom" rear bumper/tire carrier combo, rollcage...
Ex-Member of offroad nuts
LimeLite is offline
post #4 of 11 Old 09-06-2012, 06:02 PM
gojeepin
1983 CJ7
Even with a quality suspension lift, there are three main causes of rough ride.
1) Over-inflated tires... many of us mount tires with stiff side walls intended for much heavier vehicles. They won't require a very high pressure to maintain full inflation.
2) Over-torqued suspension bolts... too much resistance will keep the suspension from free movement.
3) Shocks that are too stiff... too much resistance will transfer road shock directly to the frame.
Correcting these three aspects of your suspension will improve your ride.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 11 Old 09-06-2012, 06:19 PM
benwilde
I second the tire pressure comment. I ran mine at 35 Si like the tire said until it was brought to my attention that that psi is bases on a certain weight. I run 33" Big o xt's at 20 psi front and 15 psi rear...made a huge difference .
benwilde is offline
post #6 of 11 Old 09-06-2012, 08:25 PM
robert1973
1977 CJ7
I run pro comp 2.5 springs. Mine have softened up pretty good. I never thought they were all that stiff to begin with. If you wheel with them they will loosen up quicker.
ΜΟΛΩΝ ΛΑΒΕ
The Right is wrong and the Left is stupid
robert1973 is offline
post #7 of 11 Old 09-06-2012, 09:10 PM Thread Starter
tmholland
1980 CJ5
If I would have gone with no lift and put new leaf springs and shocks on would that have made any difference?
post #8 of 11 Old 09-10-2012, 09:59 AM
dukeryder
Wow that seems really low, have you done the chalk test? I've been afraid to drop down that low on my CJ5, but nothing seems to make the ride any better. I'm running 32" BFG ATs, Skyjacker 2.5" superride with Ranch 9000XLs in the rear and some junk KYB Excel-G front shocks. I've made sure everything is greased, loose and free but it's still a brutal ride (offroad, it's fine on the street).
My ride is so rough that my girlfriend thought her insides were damaged after driving up the east side of Rollins pass.
dukeryder is offline
post #9 of 11 Old 09-10-2012, 05:17 PM
benwilde
Mine felt like the axles were welded to the frame. I thought that was low also, however, the jeep is so light, it doesn't even bulge the tires a bit give it a whirl.
benwilde is offline
post #10 of 11 Old 09-10-2012, 05:43 PM
OldTexas
I'm running about 24 lbs in my tires. I loaned my Jeep to my daughter once to go to the beach in Galveston. On the way back she stopped and had it checked out, washer fluid, oil, power steering fluid ect and a fellow told her that her tires were low and her put 36 lbs in each one. The next morning I went out, got into the Jeep and started for work and it rode hard as all get out. I finally figured out what she had done after about three days and let the aur back down to 24.
I've also been doing a great deal of research on ride since I am 63 and can use a touch of softness now. From everything I have seen and heard the CJ to YJ spring conversion is the way to go. Rubicon Express offers a really great kit that is 4.5" and, for about the same price, you can get 2.5" Ol Man Emu springs if you piece together all the other parts individually.
I'm going the Rubicon Express route myself.
Paved roads, another example of government waste!
OldTexas is offline
post #11 of 11 Old 09-10-2012, 06:42 PM
benwilde
I love my 4.5" Rubicon Express. My cj 5 rides softer than my '98 Dodge Dually...LOL
benwilde is offline
removing the bottom leaf from leaf springs agear Jeep CJ Forum 22 09-03-2011 04:47 PM
Xj rear springs no comp cut? CoryA Jeep CJ Forum 7 08-17-2011 09:07 AM
assembling leaf springs; are leaf springs identical for left and right side? pazur Jeep CJ Forum 8 07-15-2010 01:08 PM
Air shocks and leaf springs? anybody? MitchellMETAL Jeep CJ Forum 1 03-27-2009 05:32 AM
Leaf Springs 89yjPOS Jeep CJ Forum 5 11-19-2002 06:05 PM
