pricing a Cj5 - JeepForum.com
post #1 of 6 Old 05-18-2003, 09:16 PM Thread Starter
cj5mudman4x4
pricing a Cj5
everything i have on my 73 cj5 is listed in my sig.
one thing. the rings just blew. so i need a new block. everything under the hood is new, head, exhaust manifold, carb, battery, alternator, etc.; except the block itself. the tires have very few miles, and have about 99% tread. the body is in great shape, the paint isnt to bad, except for a discolored fender that had been replaced.the top is good. seats/ interior good. i love this jeep, the block is bad though and i bought a TJ. i need money and i actually have a 258 out of a F-100 that i am told will hook up perfect.
the ques. should i sell as is? how much?
should i replace the block with the one in the F-100? then sell? how much?
TIA
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline
post #2 of 6 Old 05-19-2003, 10:25 AM
BIGJMCCONNELL
1977 CJ7
I am no expert on this but I would say put the motor in so it runs and drives. I think you will be able to get considerably more out of it if you have the time to make the swap.
Just my .02
--john
1977 CJ-7 with Ford 302 engine
2.5 inch springs Matkins Frame with 1.5 inch body lift and all Fiberglass body D30/M20 w/3.54 gears, Moser 1-piece and Rear Aussie Locker, Jeep T-18w/Dana 20 and 35" tires Dual Flowmaster Exhaust, 6 point roll cage, OBA and a bunch of other stuff.
BIGJMCCONNELL is offline
post #3 of 6 Old 05-19-2003, 10:30 AM
CSP
Re: pricing a Cj5
Who told you that? No Ford ever came with a 258 and no Ford engine is a direct swap. The Ford six cylinders are quite a bit longer than Jeep six cylinders.
CSP is offline
post #4 of 6 Old 05-19-2003, 11:02 AM
Chad Churchill
hahah CSP! your right..
the only inline 6 they put in the F100 was the 240 or the 223..
besides the 240 and the 223, they just put the V8 into her.
I know this because 6 years ago me and my dad rebilt a 1964 F100 with a 223 in it.
but I would say if you do have a rebilt 258, put it in befor you sell the Cj5.. you can get your $$ worth out of it then..
'84 AMC CJ7.. 4" rancho 9000 9 way+ 1'' Tow Shacks+ 1'' BD, 9,000 warn winch, 33''BFG mudd, T176,Danna 300 with Twin shifter,44 front,20rear,4.56 with locks, 258beefed, w. fuel injected!,MSD,new white paint, all new intr., and two onbord airs. Member of TMTC, member of offroadministry, and go 4x4ing all over the U.S.A.!!!
'98 TJ... 4" Teraflex with rancho 9000 9 ways. 33" all's with solid Axles and 4.56 with locks.. Hunter green and ready to go..
Chad Churchill is offline
post #5 of 6 Old 05-19-2003, 11:13 AM
rustyCJ
go to a junk yard and pick up an AMC 258, you can get them for as low as $50. you can prolly just throw all the stuff from your old block onto the junkyard block and it will run, it takes a lot to wear out a 258.
the block you have is a 300 ford I6, it has a ford bolt pattern. not the same and wont work. sorry
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #6 of 6 Old 05-19-2003, 09:02 PM Thread Starter
cj5mudman4x4
my bad. geez.
so i have a 300! ok.. crap.
1973 CJ5
Help with Pricing sjecker Jeep CJ Forum 3 01-21-2009 08:01 AM
I need some help pricing pkt1213 Jeep CJ Forum 3 01-03-2008 10:32 PM
Pricing my 86 CJ rmontgomery2006 Jeep CJ Forum 6 04-23-2007 06:50 AM
need help pricing a CJ7 98formulaLS1 Jeep CJ Forum 4 04-06-2007 10:54 AM
Pricing my '82 CJ-7 willowrun Jeep CJ Forum 2 05-10-2005 01:40 PM
