For the price I had to pull the trigger - JeepForum.com
post #1 of 12 Old 04-16-2013, 09:23 AM Thread Starter
my_304_cj7
1976 CJ7
I figured I would give this a shot:
http://www.ebay.com/itm/AMC-JEEP-CJ5...018ccc&vxp=mtr
For $70 it's a gamble I am willing to take.
I plan on replacing the gear with the one from my original. Any issues with doing this?
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #2 of 12 Old 04-16-2013, 10:40 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I bought the exact same one. Same vendor. LOVE it! Made good dyno HP.
However, the one I got was equipped w/a hardened gear. I couldn't scratch it w/a new bit in my drill press. Since I have new cam, I had to buy MSD part# 8005, an IRON gear, for $50. From what I understand, and was advised by the guys I trust here, this gear would have chewed my new cams' softer gear right up..post haste.
You can search the forum for "HEI install". You'll find some good info. Like what has to be removed to make this work best.
Now if you are using your old cam, take the gear off your old dizzy, and pop it on this unit & you'll be set!
Good luck, and let us know what YOU think of it and how it performs.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #3 of 12 Old 04-16-2013, 11:17 AM
mike_bfdr
1981 CJ8
hei is the way to go
MY BUILD-----> http://www.jeepforum.com/forum/f22/81-jeep-scrambler-3-link-1507615/
mike_bfdr is offline
post #4 of 12 Old 04-16-2013, 06:08 PM
nsargeant
1974 CJ5
bought the same one for the 258 from these guys. Bought it when I was down there for the nascar race. very nice people. I switched the gear with my old one like the other guy said as it had a hardened gear. Been on there a year with no problems whatsoever.
nathan
nsargeant is offline
post #5 of 12 Old 04-16-2013, 06:36 PM
jimrs
I'm considering this upgrade on my 84 cj7. It is currently a stock setup and I'm wondering if this will cause me hassles with the CA smoggers.
jimrs is offline
post #6 of 12 Old 04-16-2013, 08:49 PM
hutch1200
hutch1200's Avatar
1979 CJ7
Should burn cleaner, no?
It should actually have a cleaner, more completely burned exhaust gas coming out. Google HEI emmisions and see what pops. I don't have that emmisions stuff here so I won't say defenitely yes. But, the info I have says go for it.
post #7 of 12 Old 04-16-2013, 09:48 PM
jimrs
Thanks for the reply Hutch. I'm not sure if my understanding is right but during the visual inspection they want it to look like it came out of the factory here in CA. Is there someone who has done the HEI mod here in CA and passed smog? Also what is the advantage of the HEI vs Team Rush upgrades? Really clueless here.
jimrs is offline
post #8 of 12 Old 04-16-2013, 10:02 PM
jeepwhore
I have the team rush done so everything looks stock (not that I have to worry about emissions) but as a bonus you can gut the stock icm and install an hei ignition module in the case. So I have the benefits of the stock look with the added performance of the team rush and hei (the stock advance curve isn't the greatest but many cheap hei's have a less than ideal curve for the 258)
Search for "team rush stealth hei" if you want more info.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #9 of 12 Old 04-17-2013, 01:12 AM
streetpro
1978 CJ7
I'm running the same unit and no smog issues here.
streetpro is offline
post #10 of 12 Old 04-18-2013, 07:26 AM Thread Starter
my_304_cj7
1976 CJ7
Thanks for the replies! Sounds like I took a pretty good gamble.
post #11 of 12 Old 04-21-2013, 07:36 PM Thread Starter
my_304_cj7
1976 CJ7
Ok, so my distributor came the other day and it looks different from the picture. On top is a cover with four black screws that covers where the plug wires connect. When I took the cover off, there was spring underneath and it popped loose. How do I make sure this is in the correct position when I replace the cover and what is it's purpose?
I'm not happy that it did not come as pictured. I specifically purchased this unit over others because of this cover. I just replaced my plug wires and now I am going to have to replace them again because it requires 45* connections.
post #12 of 12 Old 04-21-2013, 07:38 PM Thread Starter
my_304_cj7
1976 CJ7
It looks exactly like this one: http://www.ebay.com/itm/AMC-JEEP-CJ5...87dd07&vxp=mtr
