Prestolite to STOCK duraspark diagram? - JeepForum.com
post #1 of 7 Old 10-03-2013, 11:23 AM Thread Starter
WolfcreekCJ
1977 CJ7
I have searched ad-nausea for this seemingly simple operation. Trying to use the wiring harness from my 77 prestolite 304 which fits up nicely to the terminal block from the cab, to power the 360amc that came from an 82 with duraspark. there are lots of threads about upgrading to hei and all of the great things about it. i would like to use the materials at hand to get this thing operating without any more bloodletting of cash and possibly upgrade to hei at a later date.surely someone has done this. It's quite possible that I'm making this harder than it is , and I have not yet tried anything. This request is sort of a preemptive search for a clue before I attempt anything over the weekend. Any help in this regard would be much appreciated.
All it takes is time and money
WolfcreekCJ is offline
post #2 of 7 Old 10-03-2013, 11:28 AM Thread Starter
WolfcreekCJ
1977 CJ7
By the way, i realize that the 360 did not come stock in the donor, but the duraspark ignition is what i currently have available and was what i used for the test run before pulling the motor from the donor.The wiring harness from the donor is an absolute disaster but I was able to cobble it together enough for a test run prior to pulling it.
post #3 of 7 Old 10-03-2013, 04:02 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Wolf,
This write-up should help you.
Looks like you'll need a Duraspark compatible module, coil, and a resistor wire.
Matt
Matt1981CJ7 is offline
post #4 of 7 Old 10-03-2013, 04:31 PM Thread Starter
WolfcreekCJ
1977 CJ7
Once again you have helped me immensely. My internet connection is painfully slow out here in the sticks. I can generally find this stuff but it takes hours at times. Thanks to guys like you, and others, taking a few minutes and drawing on experience, My project has been much more enjoyable, if you can call this stuff fun
post #5 of 7 Old 10-29-2013, 04:03 PM
DirtyCJ7
Do you have a Duraspark diagram for a 258 I6?
Your Off Road Accessory Outlet
DirtyCJ7 is offline
post #6 of 7 Old 10-29-2013, 07:04 PM
BagusJeep
1981 CJ7
The Duraspark system is identical for 6 or 8 cylinder, it is only the later I6 that got the computer inserted into the system.
These diagrams are useful, the isometric sketch is of a Duraspark II which is basically the Nuttered and Teamrushed version, the schematic is for a 1984 with the computer still in place.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 7 Old 10-29-2013, 07:23 PM
CSP
The wiring is the same except for two fewer spark plug wires.
CSP is offline
