Prestolite replacement HELP - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Prestolite replacement HELP
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 04-21-2013, 08:19 PM   #16
86cj74.2L
86cj74.2L's Avatar
Results 1 - 10 of 17
Make: JEEP
Model: CHEROKEE
Beginning Year: 1978
Ending Year: 1978
Engine Type: V8
Liter: 6.6
CID: 401
Engine Size: 6.6L/401
Engine Family: AMC V8
Application Notes: Replaces models with Motorcraft distributor.
Make: JEEP
Model: CHEROKEE
Ending Year: 1979
Engine Type: V8
Liter: 5.9
CID: 360
Engine Size: 5.9L/360
Make: JEEP
Model: CHEROKEE
Beginning Year: 1980
Ending Year: 1983
Engine Type: V8
Liter: 5.9
CID: 360
Make: JEEP
Model: CJ5
Ending Year: 1979
Engine Type: V8
Liter: 5.0
CID: 304
Engine Size: 5.0L/304
Make: JEEP
Model: CJ5
Ending Year: 1981
Engine Type: V8
Liter: 5.0
CID: 304
Make: JEEP
Model: CJ7
Ending Year: 1979
Engine Type: V8
Liter: 5.0
CID: 304
Make: JEEP
Model: CJ7
Ending Year: 1981
Engine Type: V8
Liter: 5.0
CID: 304
Make: JEEP
Model: GRAND WAGONEER
Beginning Year: 1984
Ending Year: 1991
Engine Type: V8
Liter: 5.9
CID: 360
Make: JEEP
Model: J10
Ending Year: 1978
Engine Type: V8
Liter: 6.6
CID: 401
Make: JEEP
Model: J10
Ending Year: 1979
Engine Type: V8
Liter: 5.9
CID: 360
Make: JEEP
Model: J10
Ending Year: 1988
Engine Type: V8
Liter: 5.9
CID: 360
Make: JEEP
Model: J20
Ending Year: 1978
Engine Type: V8
Liter: 6.6
CID: 401
Make: JEEP
Model: J20
Ending Year: 1979
Engine Type: V8
Liter: 5.9
CID: 360
Make: JEEP
Model: J20
Ending Year: 1988
Engine Type: V8
Liter: 5.9
CID: 360
Make: JEEP
Model: WAGONEER
Ending Year: 1978
Engine Type: V8
Liter: 6.6
CID: 401
Make: JEEP
Model: WAGONEER
Ending Year: 1979
Engine Type: V8
Liter: 5.9
CID: 360
Make: JEEP
Model: WAGONEER
Ending Year: 1983
Engine Type: V8
Liter: 5.9
CID: 360
Back to Part Detail
Recently Viewed
86cj74.2L is online now   Reply With Quote Quick reply to this message
Unread 04-21-2013, 09:16 PM   #17
WindKnot
1977 CJ7
Stop Stop Stop!
Before responding to questions people should understand he has a 304 V8! So far SOME people have told him to pick up parts for the 258 I6! PLEASE DON'T DO THAT!
Jeep Hammer gave part numbers for the 258! They are WRONG! The directions are the same, but not the parts!
That distributor from Summit is correct. You want an adapter and cap for THAT distributor, not the I6.
PLUG WIRES
You'll need to be careful here. A Jeep 304 and a Jeep 360 use the same set. I cannot tell you which set because there are two different kinds of boot attachments for the distributor. My suggestion is to look at the plugs for a 1991 Grand Wagoner. My thinking is this: By then I believe the wider cap was standard and the wires should fit. CHECK FIRST!
I'd rather be lost on the trails than found at home!
[b]Phoenix Rising- A Flame Off Restoration?[/b] [url]http://www.jeepforum.com/forum/f8/phoenix-rising-flame-off-restoration-1807257/[/url]
WindKnot is offline   Reply With Quote Quick reply to this message
Unread 04-21-2013, 09:27 PM   #18
86cj74.2L
86cj74.2L's Avatar
Originally Posted by WindKnot
Stop Stop Stop!
That is why Steve posted the link for the v8 dizzy and I posted all the applications to show it can be from a lot of different models.
Unread 04-21-2013, 09:32 PM   #19
WindKnot
1977 CJ7
I see that. But they were giving part numbers for all kinds of stuff like adapters and plug wires too!
Thanks
Unread 04-21-2013, 09:36 PM   #20
86cj74.2L
86cj74.2L's Avatar
Thanks
Your right I missed that.
Unread 04-21-2013, 10:47 PM   #21
ASteve
1972 CJ5
Ok...here's an old thread I started for my 304...go here...and scroll down to "IF I WERE YOU" under jeephammer's post to me.
http://www.jeepforum.com/forum/f8/te...-304-a-924518/
[url]http://www.astevecali.com[/url]
ASteve is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 08:56 AM   #22
CSP
That isn't correct. The cap was the same from '78 through the last FSJ in '91. If the Ford type cap is used, the Ford plug wires should be used. AMC plug wires will not be correct in any year AMC V8 for use with the Ford cap.
CSP is online now   Reply With Quote Quick reply to this message
Unread 04-22-2013, 09:28 AM   #23
WindKnot
1977 CJ7
Thanks. There's the answer.
OP by now must be wondering what he got himself into!
CJput,
You're entering a world where you will want to keep a notebook of what you did to what on Your Jeep. What you're doing isn't rare, but what made life difficult is when auto part stores decided to put a computer on the counter and man it with snot nosed, pimply faced teenagers who only know how to fill out the template on its screen.
It used to be that a good counterman was worth his weight in gold. You'd tell him what you were doing and he was on to the program.
Using Ford or GM parts is not unusual. In fact Jeep did it. They outsourced lots of their parts. Some say Jeep Employs Everybody's Parts! You keep a logbook so you know which vehicle you "own" to imput into the computer to get your Jeep's parts.
Unread 04-22-2013, 02:44 PM   #24
Dngrs1
1979 CJ7
Ooops, my bad also. I saw his list of parts for an I6 and didn't realize he had a V-8. Whatever Ford V-8 application you get the cap and cap adapter from, get plug wires for the same application. They are an HEI style terminal on the cap and coil end. If you are using the stock AMC coil you will need an adapter. Or you can just pick up a Ford Ecore coil.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 02:55 PM   #25
CJput
1977 CJ7
So if I pick up a 78 or later dizzy for a 304 will I need to us the gear from the old dizzy or just run the new gear that comes as part of the Motorcraft dizzy?
CJput is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 03:03 PM   #26
ASteve
1972 CJ5
The link I posted above from Summit is a direct drop in.
SC
Unread 04-24-2013, 03:24 PM   #27
CJput
1977 CJ7
Thanks Asteve and the rest of you! your help is appreciated. I think all the extra work for the CDI system will be worth it over HEI from what I have read.
Here's where I am on the parts list for the 1977 304 Prestolite switch over:
1. Dizzy- Either 100-304891 from Summit or a Motorcraft from my auto parts store. Summit is drop in, if I go with a 1978 or later will it also be drop in? Will the gear be OK? If I order locally I won't have to mess around with shipping a core back to Summit.
2. MSD Street fire ignition (MSD 5520)
3. Cap Kit (MSD 8414)
4.Adapter plug (Jeep/Motorcraft dizzy to MSD CDI Module) (MSD 8869)
5.Wiring extension (MSD 8862)
6. Plug Wires- (MSD 3119)
Time to go to work?
Unread 04-24-2013, 05:03 PM   #28
WindKnot
1977 CJ7
No need to change gears. That's why that one was chosen.
Unread 04-24-2013, 05:34 PM   #29
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
CJput,
I thought I'd give you some visual aids.
I'm running a "Team Rushed" Motorcraft dizzy, with MSD module, coil, and wires.
Be advised, you may have to fashion a retainer clip to keep the cap adapter from spinning on the dizzy's housing.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 08:30 PM   #30
CJput
1977 CJ7
Thanks Matt. I'm slobbering all over my desk! What a good looking engine compartment and 360! The visual really helps. I think I'm going to lock-n-load on getting my parts ordered. I'm also envious of your power steering but thats a project and parts search for another day.
Nice ride!
