Powerglide Transmission Questions - JeepForum.com
post #1 of 6 Old 03-01-2013, 10:03 PM Thread Starter
JMonument
I've asked around without any real clear answer... What model powerglide would be in my 1970 Jeep DJ5? I shot a few older powerglide listings to a few people and got a brief "this won't fit your DJ, it's an older cast iron model..."
Questions:
What powerglide is in my DJ?
What rebuild kit would you recommend?
How many different types/models of powerglides are there?
Thanks
1970 Kaiser Jeep DJ-5 A
1971 Jeep CJ5
JMonument is offline
post #2 of 6 Old 03-02-2013, 07:40 AM
CSP
A powerglide is basically a powerglide. A rebuild kit that works for one will work for any other PG.
CSP is offline
post #3 of 6 Old 03-02-2013, 05:25 PM Thread Starter
JMonument
Are all rebuild kits made equally? Any brands I should stay away from? Found one for $41 on Summit Racing: http://www.summitracing.com/parts/tc...0/media/images
1971 Jeep CJ5
post #4 of 6 Old 04-29-2013, 06:28 PM
KGBnumber1
KGBnumber1's Avatar
unless youre doing a 4x4 conversion, drop the powerglide and grab a different transmission. the powerglide is old as old can be, and has TWO gears.
you can grab th350's and th400's from junkyards for a dime a dozen.
or better yet, i can sell you my built 700r4 with overdrive when i pull it out. its got about 5k miles on it, new clutch packs, performance valve body... its great, except too long for a 4x4 setup in a dj5
Blue Jeep Club member #100
1970 DJ-5
3.8 v6
700R4 tranny
countless hours of blood and sweat turning it into a cj-5
KGBnumber1 is offline
post #5 of 6 Old 04-29-2013, 07:52 PM
lucdog
lucdog's Avatar
1980 CJ5
This^^. Early glides used a cast iron case, later models used aluminum.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #6 of 6 Old 04-29-2013, 08:19 PM
dg6772
If you ditch the early power glide you may want to post it on some racing forums. The cast iron glides used to be very desirable for drag racing, handling a lot of horsepower. You may be able to sell it for enough to replace it with something a little newer and easier to maintain or repair.
Dave in Muskegon
dg6772 is offline
powerglide , transmission
