power steering vs. manual steering - JeepForum.com
post #1 of 8 Old 04-26-2004, 07:19 AM Thread Starter
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I just got the jeep running and I finally was able to pull it out under its own power. What I am seeing is still quite a bit of effort to turn the 33X15X12.5 mud meats even though I converted to power steering.
Since I have never really driven a Jeep with these size tires, I guess I am wondering how much effort usually is required to turn the tires as a stand still as well as how do I know if the power steering is even working? I have the reservoir hooked up, fluid is in it and the belt is spinning it.
Just curious if anyone has any ideas.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #2 of 8 Old 04-26-2004, 07:32 AM
OKJeepin
OKJeepin's Avatar
I too just completed a power steering conversion on mine, I have at the moment a set of 33x12.5x15 Super Swampers on it and I can turn the wheel with one hand easily, and thats with the hubs locked in and a lockright locker in the front.
When I first got it all hooked up, I could not hardly turn it, found the pump to be bad, replaced it and it works great now.
1974 CJ-5 (Rockcrawler)
2001 Grand Cherokee Laredo (Curbcrawler)
OKJeepin is offline
post #3 of 8 Old 04-27-2004, 08:30 AM
Knight6
Knight6's Avatar
Should turn very easy lock to lock with your hand open palm against the steering wheel. If you have to grab and tug or pull its not working right.
By the way, one of the best mods I ever did. I still remember the guys on the trail heckling me everytime I was on an obstacle yelling out "Power steering's Cheap!" as I was muscling through the rocks with 31's. I have 35's now and they turn with no effort.
KNIGHT6 - '78 CJ5.
Ford 9" x2, Tru-Hi-9 High pinion, 5.14s, 2 detroits,
SOA, D44 'flat-knuckles' High Steer over springs,
Chevy 5.7L Vortec, Ford T-18 with granny-low 1st
37x14.00 Iroks, Warn 9K lb winch,
Metal Fusion tube fenders,full cage frame tie-in, +++
Knight6 is offline
post #4 of 8 Old 04-27-2004, 11:04 AM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
How did you tell that the pump was bad? Mine is tough to turn, but there is no indicatoin of seizing or anything. How can I test this to see if I have air in the lines or something? If there is air in the lines, would that cause issues of not working properly?
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #5 of 8 Old 04-27-2004, 11:51 PM
CSP
Did you bleed out the system or just dump fluid in it and go? Have you bothered to check the fluid level since the install?
Jack it up so the front tires are off the ground. Keep the cap off and add fluid til it's full with the engine running. Slowly turn the steering wheel from lock to lock while keeping the fluid level full. If you have foam, it's from air being pumped out. Repeat until no more foam is made, no more groaning noises are made, and the fluid level stays full.
CSP is offline
post #6 of 8 Old 04-28-2004, 05:39 AM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
I installed it, poured fluid in it, and that was about it. I have added more fluid off and on since the install, but the motor has been running many times since then.
I will try what you say, but there is no noise whatsoever coming out of it. It appears to be working in all facets, but it is extremely hard to turn the wheel...
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #7 of 8 Old 04-29-2004, 11:12 PM
CSP
My guess is you burned up the pump by not bleeding it out properly and keeping the level where it should have been before driving it.
CSP is offline
post #8 of 8 Old 05-25-2004, 12:15 PM
Eddo
Eddo's Avatar
Just did a power steering conversion and had the same problem. Seemed harder to turn with the conversion. Pulled the return hose and it was just barely slowly flowing out. Not the 1.25 GPM it is rater for. Replaced the pump and worked like a charm. Almost turns too easly now. However, the seal between the reservoir and the pump is leaking pretty bad now. Going to see if I can pull the pump and put it in the other reservoir with the broken pump.
81 CJ 5
03 KJ LE
Eddo is offline
power steering to manual steering? sbcranger Jeep CJ Forum 10 07-29-2009 07:53 AM
Can I use manual steering brackets with power steering box? Mud Machine Jeep CJ Forum 2 12-27-2005 10:26 PM
Manual-Power Steering HELP! sac26 Jeep CJ Forum 1 11-11-2005 09:07 PM
Power steering to manual? Fropleyqk Jeep CJ Forum 9 03-12-2005 08:11 AM
Manual Steering to Power Steering 79 CJ7 Spurgeon Jeep CJ Forum 3 09-25-2003 08:25 PM
