Power Steering VS. ATF Fluid - JeepForum.com
post #1 of 9 Old 05-02-2010, 05:14 PM Thread Starter
specwarCJ
1982 CJ7
So I discovered that the PO was using ATF fluid in the power steering pump instead of PS fluid. I did some research and there seems to be several people on both sides of this issue.
My question is. Will it damage it?
I am switching back to power steering fluid I just wanted to know if I should expect more problems coming my way from using the ATF fluid.
specwarCJ is offline
post #2 of 9 Old 05-02-2010, 05:51 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Depends on the type of ATF.
Was it Ford Type F? Lots of P/S systems called for that.
Pacfanweb is offline
post #3 of 9 Old 05-02-2010, 06:04 PM
creepyjon
1953 CJ3B
use type F ford atf, on some of the older fords using regular power steering fluid is actually bad for your car. Of if you are really worried about your ps system, add some lucas into it. That stuff is magic in a bottle, I've seen it do some amazing things first hand!
creepyjon is offline
post #4 of 9 Old 05-02-2010, 07:14 PM Thread Starter
specwarCJ
1982 CJ7
There is no telling what type of ATF it was. The person I bought it from had traded a mud truck for the Jeep and so he didn't know anything about it other than how much he wanted for it.
I was mainly concerned about the seals and any other plastic or rubber components getting ruined by the ATF.
post #5 of 9 Old 05-03-2010, 03:24 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I switched from P/S fluid to Mercon V in my Ranger and F150. The normal Ford P/S whine/growl disappeared, and it never leaked in either of them.
Rick
Cutlass327 is offline
post #6 of 9 Old 05-03-2010, 04:45 AM
Oily
Some also actually call from Dexron II. Go figure.
Power steering is basically hydraulics. Ten weight hydraulic fluid should also work.
Oily is offline
post #7 of 9 Old 05-03-2010, 06:38 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Type F is totally different than Dexron II, at least as far as transmissions go.
You need to use the correct fluid. Yes, it is hydraulics, but you can't use plain old hydraulic fluid for long....there's a reason they specify the type of fluid they do.
post #8 of 9 Old 05-03-2010, 07:02 AM
halpeters
1978 CJ7
Transmission fluids are different due to "friction modifiers" that are part of the blend.
An Automatic transmission has "wet clutches" that run in the oil similar to a most modern motorcycle clutches (not exotic race stuff, or "dry clutch", etc). The transmission fluid needs to be matched to the clutch type in the transmission, thus the different types "Type F", Dextron, etc. are blended with friction modifiers to match the needs of the clutch....
In a power steering system, there are no clutches or friction plates, so I can't see how any of the trans fluid would hurt anything. Probably any 10wt non detergent oil would be fine. I think you could even get away with 30wt non detergent oil in a pench - at least in Florida during the summer...
Oh, if you ever wondered why transmission fluid is red (or Royal Purple is Purple), it is only a dye added to the oil to identify the type - the color has nothing to do with anything important.
Hal
1978 CJ-7
halpeters is offline
post #9 of 9 Old 05-03-2010, 10:40 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
There may be some other additives for seals and such, but I've always used Dex 3/Mercon in my vehicles. It always seems to be on hand, compared to p/s fluid.
As for the statement from Hal, if you were to lift the hoods of a Freaightliner, Pete, KW, or even the Volvo, one truck specifies 15w-40, one may spec P/S fluid. They use the engine oil figuring a driver would have that on hand (always carry a spare gallon to top off the engine) compared to having another bottle of P/S fluid too. They have to haul everything everywhere, so less to carry = more living space.
Rick
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Power Steering Fluid ozjeep Jeep CJ Forum 7 10-21-2007 10:41 AM
Power steering fluid everywhere! CJeep Jeep CJ Forum 1 10-21-2007 08:38 AM
Power steering fluid leak gestuhlm Jeep CJ Forum 2 05-16-2006 08:30 AM
Power steering fluid for '83 6 cyl CJOOP7 Jeep CJ Forum 3 06-04-2003 06:44 AM
