power steering temporary fix - JeepForum.com
post #1 of 6 Old 03-24-2003, 06:04 PM Thread Starter
toastdfunk
I recently blew out the pressure hose in my power steering system. Can anyone suggest a temporary fix so that I can drive the jeep approximately 50 miles to a shop? It's an '82 cj7 with a 258 and smog. Thanks.
toastdfunk is offline
post #2 of 6 Old 03-24-2003, 06:47 PM
CSP
Get a new hose, some power steering fluid and change it out yourself. Other than that no temporary fix will hold up to the pressure exerted on that hose.
CSP is offline
post #3 of 6 Old 03-24-2003, 08:03 PM Thread Starter
toastdfunk
Can you suggest a solution to loosening a nut with 22 years of non movement? I'm working in a very tight spot on the lower pressure hose attachment.
post #4 of 6 Old 03-24-2003, 11:34 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Feel free to drop the box if you need more room. Also, if you don't think you can loosen the nut without rounding it off, cut the steel hose above the nut(since the hose is bad anyway) and use a socket or box end wrench.
jeepdaddy2000 is offline
post #5 of 6 Old 03-25-2003, 02:06 PM
CJMONEYPIT
remove the pump belt and drive it with manual steering. It's a bear around town, but once you get moving it's not bad at all
CJMONEYPIT is offline
post #6 of 6 Old 03-25-2003, 03:41 PM
DaRaidz
Just went through this about 2 weeks ago. I have posted some info on my repair (you can search by user name) the lower bolts on the steering box are a major pain. I ended up taking the bolts out of the inside of the fenders and then the lower body mount bolt that holds the frame to the body under the front bumper. This allowed me to raise the radiator and grill enough to work from the front. The ONLY way I could get the bolt loose was to finally use vice grips. I went ahead and changed both hoses since I decided I didn't ever want to do it again. Good luck bleeding the air from the lines. I still can't get mine to work 100% right....but I haven't had much time to work on it lately. Do the job yourself and save about $150-$200 for other mods.
'86 CJ7 I-6, 5 speed, 33 Pro Comp, BDS lift, CD, Hardtop and Doors, 4X Dr. Rockers, 4.88 gears, ARB Air Lockers front and rear, Dana 44 rear, 63K original miles...very sweet rig.
DaRaidz is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Steering issue...Power Steering seems too good!! 76CJ5NGA Jeep CJ Forum 12 05-25-2009 08:48 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Can I use manual steering brackets with power steering box? Mud Machine Jeep CJ Forum 2 12-27-2005 09:26 PM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 08:18 AM
