Power steering swap for 75 cj - JeepForum.com
post #1 of 6 Old 07-06-2010, 03:52 PM Thread Starter
greeninwyo
hey guys,
First off I have a 75 cj with a 304 and manaul steer, I found a j10 1979 i think with power steering on a 360. Will this be a direct bolt in swap? thanks for any help.
greeninwyo is offline
post #2 of 6 Old 07-06-2010, 04:14 PM
CSP
For the most part, yes.
You'll wanto to cut a small nipple off the end of the steering box input shaft and your existing bell couple should slide onto it. You'll need the pitman arm for a power steering CJ. The J10 pitman is too long and the hole for the drag link end is too large for the CJ part. You'll need to get hoses for any '79 or older CJ with the V8. The FSJ hoses (at least the supply hose) will not be compatible with a CJ.
CSP is online now
post #3 of 6 Old 07-06-2010, 08:05 PM Thread Starter
greeninwyo
hey thanks CSP, I wasnt sure if the shaft length was the same and was going to install new hoses.
post #4 of 6 Old 07-07-2010, 08:21 PM
Rattyflatty
1948 CJ2A
I think you will need to find the CJ P/S box mount brackets.
Rattyflatty is offline
post #5 of 6 Old 07-08-2010, 07:33 AM Thread Starter
greeninwyo
I crawled under the j10 last night and it has the one piece bracke for the box. I will tear into it tonight sometime.
post #6 of 6 Old 07-08-2010, 08:13 AM
CSP
The same bracket is used for either manual or power box on '72-75 CJ's.
CSP is online now
power , steering , swap , install , cj
Power steering swap '78 CJ-5 gtx6pack Jeep CJ Forum 10 12-07-2007 08:49 AM
73 cj-5 power steering swap? AZROCKRUNR Jeep CJ Forum 3 11-26-2006 09:34 PM
Power steering swap avh Jeep CJ Forum 5 10-30-2006 10:06 AM
power steering swap CJfreak Jeep CJ Forum 6 01-16-2006 08:56 AM
cj power steering swap striky Jeep CJ Forum 0 10-27-2003 12:29 PM
