Power Steering rebuild? - JeepForum.com
post #1 of 3 Old 10-09-2003, 08:14 PM Thread Starter
TrappG
TrappG's Avatar
My power steering gearbox is leaking so badly, I just let it leak out and just took the PS belt off. I know I can get a rebuild kit for it. How hard of a job is that? A new/reconditioned gearbox is a good bit more expensive than a rebuild. Should I attempt the rebuild or buy a new one? I'm all about saving a buck if it's not a royal pain to rebuild.
'78 CJ7 - 304 - Hooker Headers/Sidepipes
TH400/QuadraTrac, B&M shifter (sold spring '04)
'04 Sahara - I6, 5spd bone-stock...
TrappG is offline
post #2 of 3 Old 10-10-2003, 07:24 AM
fuzz401
1978 CJ7
the big problem can be getting the pitman arm off they can be very tight after that the seals can be a pain but done with most hand tool
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 3 Old 10-10-2003, 07:24 AM
bstruckm
bstruckm's Avatar
First figure out where it's leaking from. In my case it was the input shaft seal. I fixed it a few months ago I just bought the seal kit from Autozone for like $10.
First, remove the big snap ring on top.
Then there's a rubberized dust shield that you have to pry out. There should be a new one in the seal kit.
Now you're finally to the seal. Take a small nail and drive it through the metal part of the seal - not too deep though.
Next, take a screw and screw it into the hole so it has a good grip.
Now, grab the screwhead with some pliers and you can pull the seal out.
Installation is the reverse, without the nail hole and screw.
bstruckm is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Power Steering Box Rebuild UncleWally Jeep CJ Forum 2 10-20-2008 11:26 AM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 08:18 AM
Power Steering Box Rebuild sercher Jeep CJ Forum 9 09-28-2005 11:52 AM
Steering Box Rebuild ddn Jeep CJ Forum 4 06-09-2004 07:33 PM
