Power steering question - JeepForum.com
post #1 of 11 Old 10-02-2011, 08:03 PM Thread Starter
popeyefireman
1980 CJ7
K, so I did a 4.3 v6 conversion and I'm at the point where I'm putting everything back on the engine. So I have a cooktops question for those that have done the v6 or chevy 350 v8 conversion. Do I use the power steering pump from the original jeep or do I use a chevy power steering pump. I wasn't sure if there would be pressure differences. I know the old pump needs replaces because prior to the build there was no power steering and the master cylinder set up seemed ok so I'm guessing it's the pump. Below is the specs if that helps.
Chevy 4.3 liter v6 with vortex
4 brl carb intake with carb
Th350
Dana 300
3 core aluminum rad with trans cooler
No air conditioning
Let me know if you have any questions.
popeyefireman is offline
post #2 of 11 Old 10-02-2011, 08:19 PM
petey156
run the chevy pump, jeep used general motors steering pump, probally the same pump different pulley.....
petey156 is offline
post #3 of 11 Old 10-03-2011, 04:27 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
yes keep the one on the 4.3...
just need to make sure you have a PS gearbox that is set up for o rings (newer) and not flairs (older).
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #4 of 11 Old 10-03-2011, 04:37 PM
petey156
He could get custom lines from Napa. They are usually cheaper..
petey156 is offline
post #5 of 11 Old 10-03-2011, 06:22 PM Thread Starter
popeyefireman
1980 CJ7
I'm pretty sure it's flairs on a 80 cj7 box. Info on the napa ones would be helpful
post #6 of 11 Old 10-03-2011, 06:23 PM
Falcon_CMH
Your correct for 1979 back. 1980 forward its o-ring
Bought a 1980 CJ-7 that I am rebuilding ground up:
Given 6 hours to chop down a cherry tree a famous person once said I would sharpen my axe for 5 hours.
Falcon_CMH is offline
post #7 of 11 Old 10-03-2011, 06:25 PM
Falcon_CMH
These guys have some cool upgrades so you can use the o-ring: http://www.agrperformance.com/Off-Ro...erformance.htm
Good reference thread here too: http://www.offroaders.com/info/tech-...ct-cj7-agr.htm
P.S. I am looking at upgrading my steering is how I found this stuff.
post #8 of 11 Old 10-03-2011, 06:28 PM Thread Starter
popeyefireman
1980 CJ7
My gear box is good. I'd rather spend the money on something else. Like a good tbi setup
post #9 of 11 Old 10-03-2011, 06:30 PM
Falcon_CMH
Sure I gotta do something there too myself sooo many upgrades to do weeeeeeeeeeeee!
post #10 of 11 Old 10-04-2011, 03:32 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
wow dont know how hard it would be to bring up to speed but you could probally get an injected manifold from a blazer and get yourself a stand alone ECU and you'd be set....
THe guys out on s10forum were a big help when it came to some of my 4.3 problems...
post #11 of 11 Old 10-04-2011, 09:36 PM Thread Starter
popeyefireman
1980 CJ7
I have the tbi manifold. Need the FBI and computer with harness. Pick and pull should take care of it I would think.
