power steering pump swap - JeepForum.com
post #1 of 2 Old 09-22-2002, 09:17 AM Thread Starter
derm
i have a 78 cj5 with 258, early full restoration, the old ps pump was installed wrong, the pivot bolt was not put in and the pump was pulled onto the manifold and melted, i obtained a replacement pump from a cj8, i think an 83 with 258 as well and brackets, it looks like it will bolt in. can i straight swap this? the newer pump has a second small pulley in front of the larger one, what is this for? i bought valvoline dextron3/mercon atf for this, is that an appropriate fluid? the pressure hose to the steering box is in poor shape and i will have to replace it, the attatchment at the box is in a nightmare spot, do i have to pull the whole radiator to get there or do i just have to put my head and shoulders in the engine compartment, sorry for all the questions, thanks for any help, derm
derm is offline
post #2 of 2 Old 09-22-2002, 07:32 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Both pumps should be the same, however, you should be able to swap the tanks. As for the pulley, as long as the driven groove is the same size and lines up with whe belts, it shouldn't be a problem(the second groove is probably for an air pump). If the grooves don't line up, then pull off the pulley(with the proper puller) and swap them over. Be sure to pull the pulley back on using a bold in the threaded hole in the shaft. Good luck
jeepdaddy2000 is offline
Power Steering Pump ?? imafishingfred Jeep CJ Forum 9 04-29-2016 08:05 PM
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
NEW POWER STEERING PUMP IS BAD(i think) poolshark909 Jeep CJ Forum 2 09-17-2008 11:15 PM
Power Steering Pump ???? Axe_Em Jeep CJ Forum 1 09-22-2006 08:34 AM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 08:18 AM
