power steering pump pulley - JeepForum.com
post #1 of 7 Old 11-10-2002, 04:04 PM Thread Starter
jeepdad40
I pulled my power steering pump off to put a new one on. I can't get the pulley off for nothin. I used a 3 arm pulley puller and it just started bending the pulley. Any ideas? This is a factory pump on a 304. . Thanks!!
jeepdad40 is offline
post #2 of 7 Old 11-10-2002, 04:16 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Re: power steering pump pulley
They make a special puller that works good - it is available at most any auto parts place for about $20
Steve
OldJeepguy is offline
post #3 of 7 Old 11-10-2002, 04:42 PM Thread Starter
jeepdad40
hey Oldjeepguy thanks for the reply .how is this puller different from the 3 arm puller that I've tried? I'll gladly pay 20 bucks to get this stubborn s.o.b. off! Have you taken any power steering pump pulleys off? I swear if it's gonna be an easy job it'll be a pain in the butt for me.!!!! I can turn a 20 minute job into 2 days!
post #4 of 7 Old 11-10-2002, 05:37 PM
55-willys
if you notice on the pulley right at the center where it fits on the shaft youll see a recessed area on the pulley around the center, thats where the pulley puller grabs. so your hooking around the center and pulling it right in the center. if you takeit to checker auto, or auto zone, they have the puller and will do it for free.
paul
55-willys is offline
post #5 of 7 Old 11-10-2002, 05:53 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
I've actually done (2) CJ's and (3) XJ power steering pump replacements this year. The proper puller hooks into the groove in the pully center and exerts force near the shaft. Trust me, you probably won't get it off without the correct puller.
Steve
post #6 of 7 Old 11-11-2002, 09:12 AM
Crash&Burn
Another option would be heat, heat the part with the groove and then let it cool down and try again..
If still no luck heat it again and try while still hot.......
Correct puller still the best way.....
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #7 of 7 Old 11-11-2002, 11:00 AM
scottahicks
scottahicks's Avatar
Hey man I just did mine this week, the only way to do it is with the correct puller, if you and to make it easier heat it up a little and spray some wd-40 on it while its still hot then pull it off just dont burn yourself OH and dont use the crapy installer that come in the box try to barrow the installer from a shop good luck,, its a workout
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline
Two Groove Pwr. Steering Pump Pulley 76driver Jeep CJ Forum 2 08-19-2009 06:15 AM
Power Steering pump, pulley and res. JeffMcBusa Jeep CJ Forum 2 04-18-2009 12:27 PM
304 Power Steering Pump Pulley Flange Jeep CJ Forum 2 07-23-2008 06:57 PM
power steering pulley mrowe26 Jeep CJ Forum 1 04-03-2006 11:47 PM
81 Cj Power Steering Pulley J33P1N Jeep CJ Forum 3 01-13-2004 04:40 PM
