Power steering pump bad? or Bearing? - JeepForum.com
post #1 of 5 Old 06-27-2013, 01:13 PM Thread Starter
DropeTine99
1981 CJ7
I've got a 81 CJ7. i recently had a cracked power steering hose so i took off the power steering belt and drove it home. Then the next day i started the jeep and it was squealing really bad. I thought once i put the power steering belt back on it'd even out the tension being pulled from the fan belt (think i tightened it to much) so i fixed the hose problem then put the power steering belt back on and it was still squealing. loosened the fan belt and the squealing stopped. BUT then when i turn the wheel it squeals and slows down the power steering pulley to a crawl. So when I think i either burned up the power steering pump or ruined the bearing on it or the bearing on the fan belt (because it was squealing even with the power steering belt off)
Don't hit kids, no seriously they have guns now.
Looking for rebuilt T-5 transmission.
DropeTine99 is offline
post #2 of 5 Old 06-27-2013, 01:53 PM
agear
You obviously put fluid back in there.........
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #3 of 5 Old 06-27-2013, 02:15 PM
pman
Did you bleed the pump? You might have air in it. The old ham can PS pumps are actually very easy to rebuild if you'd prefer not to buy a new one.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #4 of 5 Old 06-27-2013, 02:21 PM Thread Starter
DropeTine99
1981 CJ7
Lol yeah i filled it up with fluid and no i didnt. i just kept filling it when it'd run out. and ill rebuild one if i can
post #5 of 5 Old 06-27-2013, 02:54 PM
LumpyGrits
Take all the belts off.
See how easily and smooth the alt, W'pump and P/S pump turn by hand.
LG
LumpyGrits is offline
belt , cj7 , power steering pump
