Power steering groans! - JeepForum.com
post #1 of 4 Old 07-28-2013, 07:37 PM Thread Starter
HMS
1983 CJ7
My power steering started to groan when making turns lately. Removed old fluid and replaced with new and problem remains. Seems to get worse the longer the drive or the hooter it gets. Any ideas what's wrong?
83 CJ7
258 bone stock
HMS is offline
post #2 of 4 Old 07-29-2013, 12:23 AM
82JeepCJ7
1982 CJ7
Most of the time, a groan is caused by air trapped in the system. I would say that it's had ample time to work its way out. I would look into replacing the pump. The groan you hear is cavitation inside the pump. They are fairly easy to replace. If you don't already have the correct tool for removing/installing the pulley, I suggest buying one. I "rented" one (same cost, was brand new) and never returned it. I have used it countless times on my vehicles, friends vehicles, etc.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 4 Old 07-29-2013, 01:15 AM
SJ85CJ7
If you buy a new pump to replace the old one no problem, but if you get one from a donor vehicle just remember that 1980 to 1985 are metric pre-1980 are standard threads on the two bolts that go into the pump body and the pressure hose.
Take it from me I found out the hard way :
85' CJ7, 258 I6, "Team Rush" Weber 38/MSD 6A, T-176 4-speed, twin-stick Dana 300, DANA 30 fore - AMC 20 aft with stock 2.73 gears, 31" tires, 8k winch, "Dirtworx" rear bumper/tire carrier. My Daily Drive, JustEmptyEveryPocket
SJ85CJ7 is offline
post #4 of 4 Old 07-29-2013, 07:41 AM Thread Starter
HMS
1983 CJ7
Thanks guys, I guess I'll just put in a new pump. Never had one go bad before.
HMS is offline
