power steering/brakes - JeepForum.com
post #1 of 5 Old 06-26-2002, 04:47 PM Thread Starter
Southern Comfort
Post power steering/brakes
have just picked up my cj-6--it is a 74 w/ 304 and a 3 speed--am am interested in installing power steering and brakes--anybody had any experiences with these installs good or bad please let me know--thanks
80' CJ 7---304 4bbl w/ alum intake--4 spd--4" skyjacker---1" body---33 x 14.50 Boggers
Southern Comfort is offline
post #2 of 5 Old 06-26-2002, 08:19 PM
cjdriver
cjdriver's Avatar
Post
I have used the Off Again Navajo booster to convert my CJ to power brakes. It works awesome. You get a bigger double diaphram booster than stock, and then you use a J series truck master cylinder and they are strong. It works great, I can lock up my 36" swampers with it. You can get info from <a href="http://www.mepco4x4.com" target="_blank">www.mepco4x4.com,</a> you might have to mail them, I dont think its on their site.
As for steering I cant help you there. But you should be able to scavange the parts from just about any CJ cause the steering design on yours is similar to all the late model CJs. Just get the brackets and stuff from a CJ with a similar engine as yours and you should be golden. Put like a AGR box and pump in there and you should be in good shape. Shouldnt be too hard.
Jim Sykes
motorsports photography
cjdriver is offline
post #3 of 5 Old 06-27-2002, 06:53 AM Thread Starter
Southern Comfort
Post
couldn't get the link to come up for mepco--anybody with any ideas on how to contact them?
thanks!
post #4 of 5 Old 06-27-2002, 05:30 PM
cjdriver
cjdriver's Avatar
Post
Sorry the comma screwed it up. <a href="http://www.mepco4x4.com" target="_blank">www.mepco4x4.com</a> and their 800 number is 1-800-388-5337.
Jim Sykes
cjdriver is offline
post #5 of 5 Old 06-27-2002, 06:15 PM
only in a jeep cj
Post
Hey Southern Comfort, Welcome to the few, the CJ-6 owners. I too am doing the power upgrades to my 6. Mine is a 75 model with the 258 6 cyl. That's neat you got a 304 model. Does yours have a tailgate, my doesn't and I haven't seen another one with out.
Unfortunatly, my fathers car was totaled out and we bought it back from the insurance company. What I found was the power steering box from the 73 Pontiac Grandville was almost a direct match too the power boxes used in the CJ's. The difference is the CJ units have the numbers 76 cast into the housing. This one doesn't because it's a bigger bodied unit. The mounting holes are a dead match and the splines on the steering shift are a match, so is the over all length of both the units body and the pitman arm. The tierod hole is correct and the arm has a slight drop to it where the CJ arm is straight. The only different is one of the hose fittings (return line I think), but there is an adaptor for that. The few times I drove the Pontiac, the steering was incredibly easy to turn (ie very powerful for such a big car). You could almost blow on the wheel and it would turn. This should be a great box. The pump is the same too, but I'm getting the proper brackets to fit it to the 258. I'm also swapping in wide track CJ axles to gain disc brakes and a wider track width as well. I haven't figured out the power brakes yet, but I do have the Pontiac set up in case I can use any parts from it.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
Need opinion....Manual Brakes/360 to Power Brakes Rollbar Jeep CJ Forum 16 04-08-2009 11:06 PM
Converting to power brakes, steering... 78 CJ5 Cutlass327 Jeep CJ Forum 2 04-05-2009 08:46 PM
Power steering and boosted brakes question CJ5Freak Jeep CJ Forum 0 07-23-2008 09:13 AM
power steering and power brakes 1976cj7 Jeep CJ Forum 3 03-09-2007 04:05 AM
Hydraulic brakes to power brakes question Jeep'N 4 Fun Jeep CJ Forum 5 03-05-2003 11:00 PM
