power steering box problems - JeepForum.com
post #1 of 3 Old 04-02-2009, 11:36 AM Thread Starter
CJGUY
1978 CJ5
well another set back in my project iam just about to drive this thing for really the first time and while iam trying to bleed the power steering all of a sudden it starts streaming out fluid at the box right at the steering shaft. I dont know how this could be happening because it is a brandnew box yes its been sitting for quite a while because of a long project but its not like it was outside. I had the front end raised off the ground and the pump full of fluid, i let it run for about 3 min or so and put a little more fluid in. Then i started trying to cycle the suspension when the steering wheel starts shaking violently where i can barely grab the wheel, when i do get the wheel under controll the motor dies. I have no idea what is goin on so i tried it again, let it run for 3 min, checked the flui in the pump and then trying to cycle the supension again. The wheel again started shaking violently and something let go and the box starts pissing fluid like a waterfall out of the box near the steering shaft. If you have any ideas it would be much appreciated, i was thinking about getting a junk yard box and seeing if it would do the same but i dont have much cash since the project has ate it all and i cant work now cause iam in college. Also excuse the grammer just dont have much time.
CJGUY is offline
post #2 of 3 Old 04-03-2009, 05:55 AM
Mike Romain
You should look really close at the fittings to be sure is isn't just a leak there. If the shaft is indeed leaking out it's seal, it is a bad box. I don't know where they are getting these remanned POS parts these days, but I have only had one brake master work out of the las 8 I have bought and I now need number 9.
I just put a new frame in mine so had to swap over the steering box. One month later the steel line above the fitting on the pressure hose blew out.
Mike
Mike Romain is offline
post #3 of 3 Old 04-03-2009, 03:53 PM Thread Starter
CJGUY
1978 CJ5
it is not coming out of the hoses or the fittings, i wish it was. ill try a juck yard box and see what happends.
CJGUY is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Steering issue...Power Steering seems too good!! 76CJ5NGA Jeep CJ Forum 12 05-25-2009 08:48 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Can I use manual steering brackets with power steering box? Mud Machine Jeep CJ Forum 2 12-27-2005 09:26 PM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 08:18 AM
