power steering box leak. - JeepForum.com
post #1 of 6 Old 10-23-2008, 11:28 AM Thread Starter
Petescj
1978 CJ5
I know this has probably been covered already but Im pressed for time at work and dont have time for a good search. My power steering box is leaking from the back end by the steering shaft. Can you just replace the seal? Does it need pressed in? Ive seen rebuild kits for them but not just that seal. Mine works fine just leaks. Im already getting new hoses due to some dry rot. Thanx
Pete
Petescj is offline
post #2 of 6 Old 10-23-2008, 12:39 PM
64Jeeper
1964 CJ5
As far as I know, I think you can just replace the seal.
64Jeeper is offline
post #3 of 6 Old 10-23-2008, 01:27 PM
Slawth
Master Rebater
Slawth's Avatar
1978 CJ5
Figure out exactly where it is leaking from first. If it is around the the adjuster ring it's the adjuster plug o-ring seal. If it is around the stub shaft (splined shaft) it is the dust and stub shaft seals. If it is between the stub shaft and the torsion bar,(protruding nipple) It is the rotary valve assembly and that will need to be replaced which means rebuild. Rotary valve assembly:
You can replace the adjuster plug o-ring and stub shaft seal separately.
Slawth is offline
post #4 of 6 Old 01-11-2009, 10:20 PM
82Renegade
1982 CJ7
I'm having the same problem- fluid leaking from the stub shaft end of the box. Several times above its mentioned that you can just replace the seal- anyone know where to get them? Don't see any in the normal catalogs.
82Renegade is offline
post #5 of 6 Old 01-12-2009, 06:24 AM
shull360CJ7
My '85 had a bad leak that started shortly after I began running 33"x12.5" tires. At the advice of other forum members, I bought some Lucas Power Steering Stop-Leak. It cost a couple bucks and stopped it immediately, which saves me from having to keep dumping in more power-steering fluid, until I can replace the box.
Forum members also suggested buying a PSC box ($200-$300, atleast) because replacing the seals is a pain and usually doesnt last. Also, my box is really worn and I have about 1"-2" of play in my steering wheel. I look at it as an anti-theft system...someone steals it, they're gonna wreck about 500 ft. later!!
'98 Sport, 5 Speed. Green Emerald Metallic. Bestop soft top.
BDS 2" lift, AR steel wheels, 31"x10.5" Goodyears. Stock axles, stock 3.07 gears.
Immigrant from the CJ world...be patient...I can be taught
shull360CJ7 is offline
post #6 of 6 Old 05-17-2011, 10:55 AM
drewster
1973 CJ5
Old thread here but that play in your steering wheel, is more likely to be your steering shaft joints with the play. buying a new shaft would fix that problem. good luck all.
20,000 JEEP PARTS AND ACCESSORIES AT THE BEST PRICES!
15% OFF STORE WIDE!!! CHECK OUT
drewster is offline
Power steering leak obscurotron Jeep CJ Forum 13 11-21-2013 03:42 PM
power steering leak WIcj5 Jeep CJ Forum 0 11-06-2009 11:38 PM
Oil leak on power steering CJ7 patcj7 Jeep CJ Forum 1 10-05-2008 11:30 AM
Power steering leak dblock16 Jeep CJ Forum 3 12-19-2006 07:53 AM
power steering leak sullju Jeep CJ Forum 13 10-12-2003 07:29 AM
