Power Steering box identification - JeepForum.com
post #1 of 8 Old 11-15-2012, 07:27 AM Thread Starter
CoolSpot
1976 CJ5
Hi every one,
New guy here! Just bought a 76 CJ5 with a couple mods on it!
I'm from Quebec, Canada
First Jeep for me... a friend of me bought a 75 Toyota Fj-40 and convince me to go Off-road
Mods I'm aware:
-full fiberglass body
-33''
-Chevy 327 V8 (from a 68 corvette)
-Front disc brakes
-Power brake (was it stock?)
-Power steering
I have a few questions regarding my steering box if anyone can help
Here's a few pictures of my steering box:
I know it's a Saginaw with inverted flare connections...but I'm not convinced that this is a CJ box...
Both lines are 3/8'' OD
Pressure line was connected to the front port(3/4) and return line was on 5/8'' port.
I ordered a rebuild kit and new steering shaft coupling and coupling does not fit, it's too big.
Last thing.. the top nut (requiring a spanner wrench) is a pita to remove... any idea were I can find a tool or something to help?
Thanks a lot
CoolSpot is offline
post #2 of 8 Old 11-15-2012, 07:38 AM
keith460
Jeep. There's Only One
keith460's Avatar
Looks like an earlier Jeep J20 box with a 3/4" Steering Gear Box Input Shaft Diameter.
Power steering gear boxes for a CJ would have a 13/16" Input Shaft Diameter and no protruding nipple.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 8 Old 11-15-2012, 07:47 AM
waterdowg
Keith may be right. Can you measure the front round part of the box? That will help a little. The J20 box is bigger, and is a popular upgrade to a CJ.
waterdowg is offline
post #4 of 8 Old 11-15-2012, 08:22 AM
lucdog
1980 CJ5
I believe the J20 box is 4" on the end, whereas the CJ box is 3.75".
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now
post #5 of 8 Old 11-15-2012, 08:39 AM
CSP
Definitely not a CJ box with that "nipple" protruding from the end of the input shaft. J-truck boxes do have that protrusion as they use a rag joint vs a bell coupler that CJ's use.
CSP is offline
post #6 of 8 Old 11-15-2012, 12:24 PM Thread Starter
CoolSpot
1976 CJ5
Outside Diameter is 3.75'' Piston looks like 3'', could be a old J10 box?
CoolSpot is offline
post #7 of 8 Old 11-15-2012, 12:52 PM
CSP
Could be a Waggie/J10/Cherokee. Those have the smaller, 3/4" input shaft.
CSP is offline
post #8 of 8 Old 11-15-2012, 07:48 PM
JeffreyCharles
1976 CJ5
I don't know the answer - haven't pulled my (non-stock) Saginaw box ever so don't know much about it. But these guys know everything so you probably already have your answer. As for power brakes, they were an option. I don't have 'em on mine. Someone drove mine the other day, just around a parking lot. Climbed out and said "there's something wrong with your brakes! I could barely stop!" hee hee. If you have me walk 100' I'll probably veer to the left a bit due to the stronger muscles in my right leg...
Meanwhile, great find! Looks just the first CJ5 I ever rode in back in the late 80's.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
