power steering for a 68 cj5 - JeepForum.com
post #1 of 7 Old 08-06-2010, 10:53 PM Thread Starter
mnky30
1968 CJ5
hi all i am new here and just got a 68 cj5 with a 225 v6 and it has manual steering on it right now and was wondering if anyone does a convertion kit from manual to power steering thanks for any and all help.
mnky30 is offline
post #2 of 7 Old 08-06-2010, 11:02 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Start with these
http://www.jeepforum.com/forum/f8/do...-swap-1065062/
http://www.jeepforum.com/forum/f8/up...shaft-1069091/
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 7 Old 08-07-2010, 05:27 AM
colojeepguy
1970 CJ5
Disregard the above info-it doesn't apply to your Jeep. Basically, youi'll have to change everything between the steering column and the steering knuckles. It's a worthwile upgrade, and commonly done, but it's not just a simple bolt-in. If you go to earlycj5.com there's TONS of info on this swap.
colojeepguy is offline
post #4 of 7 Old 08-07-2010, 10:02 AM Thread Starter
mnky30
1968 CJ5
thanks i will check it out
mnky30 is offline
post #5 of 7 Old 08-07-2010, 10:08 AM
brownbagg
1930 MK Compass
I swap mine out on my 46 cj2 wwith a 226. I went with saginaw box from junkyard off a chevy monza. pump off a 231 v6 and tie rod from advance adapher. less than $100
brownbagg is offline
post #6 of 7 Old 04-23-2012, 09:23 PM
KensCJ7
Converting my Old CJ5 to power steering
Im using a power steering conversion kit from Herm the Overdrive Guy that uses a F150 steering box. I cannot get the old 1968 steering box removed from the steering shaft. I unbolted the steering box from the frame and unbolted the steering shaft from the dash and unbolted the clamp around the steering shaft at the steering box. Ive huffed and puffed but cannot separated the two. Am I missing something?
KensCJ7 is offline
post #7 of 7 Old 04-24-2012, 05:13 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The steering shaft is part of the box. Your best best is to drop both the shaft and box out the bottom of the Jeep.
jeepdaddy2000 is offline
Power Steering and Power Brake upgrade? Chris Jeep CJ Forum 37 12-24-2014 11:02 AM
Upgrading to power steering; need to change steering shaft? Berretta Jeep CJ Forum 8 11-12-2013 06:12 PM
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 08:18 AM
