Power Problems - JeepForum.com
post #1 of 6 Old 03-08-2002, 12:33 PM Thread Starter
medinase
Question Power Problems
I have a 1981 CJ-5. The problem that I am having is that when I drive about 10 miles on the freeway I start to lose power in 3rd and 4th gear. I keep the gas pedal down but it starts to slow down almost like I had taken my foot off the gas pedal. Has anyone had this problem before?
medinase is offline
post #2 of 6 Old 03-08-2002, 03:38 PM
1911shtr
Post
Check out your carb and ignition.
1911shtr is offline
post #3 of 6 Old 03-09-2002, 07:50 PM
hamyscj
Post
Don't rule out the catalytic converter also. A simple test is to remove the head pipe bolts and drive it. It will be loud but you should be able to see if it corrects the problem. Hamy.
One Way Up Racing
Romans 10:9
hamyscj is offline
post #4 of 6 Old 03-10-2002, 12:00 AM
1911shtr
Post
thats right, I always forget that most people have emissions controls. They can also play a part in your problem.
1911shtr is offline
post #5 of 6 Old 03-10-2002, 07:50 AM
HighCountry
Post
I'll bet you are pulling a vacuum on the GAS TANK and literally running out of gas. Take the gas cap off and drive it for a while and see if that fixes it.
Bruce
HighCountry is offline
post #6 of 6 Old 03-10-2002, 06:52 PM
ilovejeeps
Post
i had same prob. with my sevem but only when hot it was my "spark box" would idle and run great but put the pedal down and you could get out and run faster. they are fairley cheap if that your problem always carry a spare even new ones can die quick.
ilovejeeps is offline
Power Problems... scamaro355 Jeep CJ Forum 3 05-12-2009 12:24 AM
Power brake problems Jeepguy91 Jeep CJ Forum 10 04-17-2009 04:51 AM
power steering box problems CJGUY Jeep CJ Forum 2 04-03-2009 04:53 PM
Power booster problems blue66tang Jeep CJ Forum 5 04-24-2006 07:32 PM
Bottom End Power Problems Techh Jeep CJ Forum 3 04-30-2003 11:15 AM
