Power drops off when at high rpm - JeepForum.com
post #1 of 5 Old 05-03-2010, 12:33 PM Thread Starter
TYoungone
1983 CJ7
Currently I have the 258 with a single barrel carb. Idles and runs great, good power. Problem is at higher rpms (not sure where no tach hooked up yet) the engine power just drops off when giving full throttle at the high end of the current gear. It just cuts out, then if I let off the gas it works as it should. Can anyone point me in the right direction...
TYoungone is offline
post #2 of 5 Old 05-03-2010, 01:44 PM
JKM3134
1983 CJ7
does your carb have a power valve?
getting enough fuel?
JKM3134 is offline
post #3 of 5 Old 05-03-2010, 07:22 PM
347FLATTY
When you give it heavy throttle or when your at high rpm's it's not getting the fuel it needs and runs into a lean condition where the fuel demand is higher than the output. It could be a number of things including fuel pressue, pump output, carb jetting... If this is a new problem it could be a pinched line, plugged filter or clogged jets if not then might be one of the previous listed issues. Hope that helps
347FLATTY is offline
post #4 of 5 Old 05-04-2010, 08:20 AM Thread Starter
TYoungone
1983 CJ7
Thanks, Looks like I'm digging back into the carb....I'm not sure if it has a power valve or not. I just bought it a week ago and am learning a lot fast.
post #5 of 5 Old 05-04-2010, 08:28 AM Thread Starter
TYoungone
1983 CJ7
Wierd thing is that I have stomp on the gas and no problem, only at higher RPMs when I step on the gas it falls flat. Recovers when I let off. Carb is stock Carter BBD. Also I guess its a two barrel. Fooled me.
Speedometer Needle Bounces then drops to 0 seagrave Jeep CJ Forum 2 10-28-2009 07:47 AM
Help - 258 Loosing Power at High Speed CJ7Driver Jeep CJ Forum 3 06-07-2009 10:01 AM
Revisit... Fuel Pressure Drops soccerpapa Jeep CJ Forum 22 09-22-2007 03:26 PM
Performance drops after warming up soccerpapa Jeep CJ Forum 28 07-12-2007 11:06 PM
Voltage Gauge Drops w/Lights on CLEMSONTIGER Jeep CJ Forum 7 11-19-2004 07:28 PM
