Power brakes or not? - JeepForum.com
post #1 of 9 Old 06-22-2013, 06:16 AM Thread Starter
Jproy15
I figured out that my brake master cylinder is leaking. I want to order a new one but there are 2 different ones for my '82 cj7. How do I know if I have power brakes or not? Also, is there a better upgrade then the stock version everyone has for 70.00? Thanks for the info.
Jproy15 is offline
post #2 of 9 Old 06-22-2013, 06:21 AM
NoNative
In the picture below you'll see the booster between the master cylinder and the firewall. If you have one of those, you have power brakes.
I added PB to my white laredo and it made a huge difference. You can get all the parts at autozone, napa, o'reilly's etc. and it's not a very expensive upgrade if you don't have them. I highly recommend it.
1986 CJ-7 Laredo, 258, AX15, AC Dana 30/44, Ox Lockers, Howell TBI, DUI, 4.5" RE YJ Springs, 1.25" BL, clocked & twin-sticked Dana 300 with Lomax 4-1, 4.10s, 33s, PB, 8000# winch, YJ Roll Bar, Factory 20 gallon tank.
1984 CJ-7 Renegade, 258, T4, AC, Howell TBI, DUI, 2.5" OME YJ Springs, 3.53, 31s, PB, Warn bumpers & 8000# winch, Factory 20 gallon tank
1984 CJ-7 Renegade, 258, Auto, AC, 3.31s, PB, Factory 20 gallon tank, Bone stock except for 31s
NoNative is offline
post #3 of 9 Old 06-23-2013, 07:01 AM Thread Starter
Jproy15
So the only part I need to make this upgrade is the "booster" part?
Jproy15 is offline
post #4 of 9 Old 06-23-2013, 07:22 AM
NoNative
I'm no mechanic, but if you can one of the stores I listed above them can probably tell you what parts you need. Alternatively you can do a google search for "Installing power brakes on a Jeep CJ" and I bet you'll find lots of write ups on how to do it what you'll need etc. The search function within jeep forum is your friend.
NoNative is offline
post #5 of 9 Old 06-23-2013, 10:57 AM Thread Starter
Jproy15
Thanks!!
Jproy15 is offline
post #6 of 9 Old 06-23-2013, 04:23 PM
Tigerjeep79
1979 CJ7
I was thinking of this too. The reason I run 32" tires is that in my opinion 33s would be the tipping point for power brakes. Shouldn't be that hard of a swap; my only beef with it is that I'd have to give up my cool-lookin' factory air cleaner for one of those that sit on top of the valve cover. Trivial, I know.
Tigerjeep79 is offline
post #7 of 9 Old 06-23-2013, 06:16 PM
lucdog
lucdog's Avatar
1980 CJ5
Do they come with the firewall bracket?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 9 Old 06-23-2013, 07:30 PM
texasdave
texasdave's Avatar
1980 CJ7
Find a 95 wrangler you can get the parts from it to include the mounting brackets. You may have to alter the brake push rod unless you use the yj pedals.
texasdave is offline
post #9 of 9 Old 06-23-2013, 08:42 PM
NoNative
Search eBay and you should be able to find a factory air intake set for cjs with power brakes. They usually go for around 30-40 buck last time I looked.
NoNative is offline
