-   -   Power brakes or not? (http://www.jeepforum.com/forum/f8/power-brakes-not-1539736/)
Jproy15 06-22-2013 07:16 AM
I figured out that my brake master cylinder is leaking. I want to order a new one but there are 2 different ones for my '82 cj7. How do I know if I have power brakes or not? Also, is there a better upgrade then the stock version everyone has for 70.00? Thanks for the info.
NoNative 06-22-2013 07:21 AM
1 Attachment(s)
In the picture below you'll see the booster between the master cylinder and the firewall. If you have one of those, you have power brakes.
I added PB to my white laredo and it made a huge difference. You can get all the parts at autozone, napa, o'reilly's etc. and it's not a very expensive upgrade if you don't have them. I highly recommend it.
Jproy15 06-23-2013 08:01 AM
So the only part I need to make this upgrade is the "booster" part?
NoNative 06-23-2013 08:22 AM
I'm no mechanic, but if you can one of the stores I listed above them can probably tell you what parts you need. Alternatively you can do a google search for "Installing power brakes on a Jeep CJ" and I bet you'll find lots of write ups on how to do it what you'll need etc. The search function within jeep forum is your friend.
Jproy15 06-23-2013 11:57 AM
Thanks!!
Tigerjeep79 06-23-2013 05:23 PM
I was thinking of this too. The reason I run 32" tires is that in my opinion 33s would be the tipping point for power brakes. Shouldn't be that hard of a swap; my only beef with it is that I'd have to give up my cool-lookin' factory air cleaner for one of those that sit on top of the valve cover. Trivial, I know.
lucdog 06-23-2013 07:16 PM
Do they come with the firewall bracket?
texasdave 06-23-2013 08:30 PM
Find a 95 wrangler you can get the parts from it to include the mounting brackets. You may have to alter the brake push rod unless you use the yj pedals.
NoNative 06-23-2013 09:42 PM
Search eBay and you should be able to find a factory air intake set for cjs with power brakes. They usually go for around 30-40 buck last time I looked.
The time now is 09:03 PM.
