Power brake question - JeepForum.com
post #1 of 16 Old 05-02-2010, 04:46 PM Thread Starter
Badshot
I need power brakes. I read several post on it, but I want a concrete answer from someone thats done it. Got an 85 CJ7 and I want to go with the most reliable setup. Please advise.
Badshot is offline
post #2 of 16 Old 05-02-2010, 06:41 PM
4lowherewego
1979 CJ7
search yj booster conversion
4lowherewego is offline
post #3 of 16 Old 05-02-2010, 06:49 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
How much you want to spend?
How much work do you want to do?
How good are you at scrounging parts?
I went with a Vanco Hydroboost:
"In the end...It's all Hack."
HackFabrication is offline
post #4 of 16 Old 05-02-2010, 06:54 PM
John N
1981 CJ8
If your tires are 35s or smaller, a duel diaphram booster and a bigger m/c will work well, it's what I did. I got the Navaho unit from Off Again 4 Wheel Drive. The duel diaphram unit from Vanco is similar; either is excellent. They come ready to bolt in, with all brackets attached and run about $400.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #5 of 16 Old 05-02-2010, 08:27 PM Thread Starter
Badshot
$400 ain't bad. I will look into it. Thanks. I like that it bolts up and its clean to start with.
Badshot is offline
post #6 of 16 Old 05-02-2010, 11:27 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
The Vanco setup is nice, but you can probably do the 1995 YJ dual diaphragm setup twice over for that much.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #7 of 16 Old 05-03-2010, 08:40 AM
CjAl
1980 CJ7
where are you finding that vanco hydroboost for $400 because their webiste has it at $840 with lines and master cyl.
My cj has manual brakes. At this point i'd be happy just to have vacume assist as i'm not running that big of a tire. Suppose i'll just find a CJ setup and use a firebird master for rear disks, or is there a better booster design available?
CjAl is offline
post #8 of 16 Old 05-03-2010, 10:53 AM
Vancopbs
Originally Posted by PavementPounder View Post
The Vanco setup is nice (they also have regular vacuum setups in single and dual diaphragm), but you can probably do the 1995 YJ dual diaphragm setup twice over for that much.
I would never sell a single diaphragm for a CJ, that would just be evil. I only sell dual. The 1995 YJ Dual set up is as good as any dual set up if you install it right, can also be a ton cheaper.
Vacuum dual diaphragm kits sell for 425.00.
Hydroboost kits (enitre kits, hydroboost, master all the lines and fittings) run 680.00 on my site.
Van
Vanco Power Brake Supply
9738 Atlantic Ave
South Gate, Ca 90280
800-256-6295
323-563-1588
Vancopbs is offline
post #9 of 16 Old 05-03-2010, 12:31 PM
JohnnyRotten
1978 CJ5
I did a YJ booster on my 79 CJ5. Its only a single but it will lock up my 33's. I'm happy with it. 2 hours to install and $35 off of ebay.
JohnnyRotten is offline
post #10 of 16 Old 05-03-2010, 01:02 PM
John N
1981 CJ8
The $400 (approx) I quoted is for a duel diaphram set-up like I used. I don't know about hydro-boost systems. Since Van has joined in on here, I'm sure he can answer any questions....also a big benefit of using him is that he is on here.
John N
John N is offline
post #11 of 16 Old 05-03-2010, 02:07 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Are you saying the YJ setup is as good as your booster setup? I don't want you to shoot yourself in the foot here, but I was under the impression that the vanco setup addressed some alignment problems with the pedal and push rod?
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #12 of 16 Old 05-03-2010, 02:43 PM
CJ7-1986
I ordered the Vanco this am for 840.00....go big or go home!
CJ7-1986 is offline
post #13 of 16 Old 05-03-2010, 04:14 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
Less then a day after the OP and one of the vendors that was being talked about not only chimed in and corrected a mispost, but also gave you a quote.
Thats the #1 reason i went with Van.....
If you have the money and can afford it, he is highly reccomemded. Hell one time i called with a question and he was one that answered the phone...
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #14 of 16 Old 05-03-2010, 05:30 PM
CajunCJ
I went with Van's hydroboost myself. Great service from them when I called with a problem they were a big help in getting me fixed up.
CajunCJ is offline
post #15 of 16 Old 05-03-2010, 07:05 PM
rixcj
rixcj's Avatar
1979 CJ5
I have several '95 YJ Dual diaphragm MC/ booster/ proportioning valve set-ups for sale, if anyone's interested.
They are $160.00, shipped to any lower 48 states.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
Power Brake Converstion Question as71977 Jeep CJ Forum 2 10-25-2009 10:24 AM
Power Brake Upgrade question RMB Jeep CJ Forum 7 03-31-2009 05:14 PM
Power brake question BioTex Jeep CJ Forum 4 10-16-2008 02:54 PM
CJ7 Power Brake Question dcarlton Jeep CJ Forum 2 03-17-2006 07:48 PM
brake power booster question outdoordad@comc Jeep CJ Forum 2 02-28-2006 11:38 PM
