Power Brake Booster Pics - 1978 CJ7 V-8 - JeepForum.com
post #1 of 3 Old 09-02-2012, 06:54 PM Thread Starter
bigdee2
I removed the power brake booster about 10 months ago to do some work on the steering and need some guideance on re-installing it. Anyone have some pics they can send me to assist? Thanks.
bigdee2 is offline
post #2 of 3 Old 09-10-2012, 06:45 PM
tevans59
1979 CJ7
Should be a simple install, make sure the booster vacuum port is located at the top and insert the rod thru the wall and bolt the booster back up and reconnect the rod to the brake pedal, then bolt the MC back up and do not adjust the rod that goes between the MC and booster if you had good brakes before. I had to install a booster cause mine was manual and it went to smooth. oh yeah dont forget your vacuum line reconnect. You can search the forum for the pics also
tevans59 is offline
post #3 of 3 Old 09-10-2012, 08:43 PM Thread Starter
bigdee2
Sure enough - I had the rods backwards. Thanks. Nice CJ BTW!!
bigdee2 is offline
1978 CJ5 Power Brake Booster Size rbdesse Jeep CJ Forum 0 10-02-2011 10:48 PM
Power Brake Booster anyone? kvncot Jeep CJ Forum 20 07-19-2011 05:35 AM
72 CJ5 YJ Power Brake Booster? 5artist5 Jeep CJ Forum 2 03-28-2011 01:41 PM
1978 CJ5 brake booster upgrade question terryit3 Jeep CJ Forum 2 10-12-2010 04:03 PM
Power Brake Booster h2obuff Jeep CJ Forum 52 06-17-2006 05:36 PM
