Power booster problems - JeepForum.com
post #1 of 6 Old 04-23-2006, 04:25 PM Thread Starter
blue66tang
I just finished the YJ power booster upgrade, and the booster doesnt work. I can hear it leak really bad when i push the brake down. Is this thing shot or can i fix it some how? It leaks so bad it actualy causes the engine to run very poorly. Also when/if i get a new one is the MC and booster all one or can i just get the booster. I got the booster and MC from a wrecking yard for 40 bucks i think i might see if i can get some money back or trade for another one, or do you guys think i should just go get a new one? Thanks
blue66tang is offline
post #2 of 6 Old 04-23-2006, 04:35 PM Thread Starter
blue66tang
O also, what did you guys do for an air cleaner afterwards. Mine wont fit at all, because of the brake lines. Does somebody make a spacer to go between the carb and the air cleaner?
post #3 of 6 Old 04-23-2006, 05:25 PM
MeCasa
Wouldn't hurt to ask them or at least get some slack for another part, then get a new one, it's only $60 with a trade in, the bracket and MC are worth at least $40, you did OK
Sex is dirty only if it's done right .... Live and Let Live .... Rules are Boring and I Don't Like Them
................................................ MeCasaEsSuCasa .................................
MeCasa is offline
post #4 of 6 Old 04-24-2006, 04:21 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If it leaks from the cab side, the diaphragm is bad, and so is the booster. If it is leaking from he MC side, it's possable the rod seal is bad. These should be available from your local brake shop and are easy to replace.
jeepdaddy2000 is offline
post #5 of 6 Old 04-24-2006, 06:14 PM
LuisR
I did the swap not to long ago, I had the same problem with the air filter no fitting, had to buy a tear drop air filter and it work out nice. just my 2 cents. I will sugest that you do put the nut in the push rod is nice to be able to adjusted. later dude
LuisR is offline
post #6 of 6 Old 04-24-2006, 06:32 PM Thread Starter
blue66tang
Does anybody make any spacers for the air cleaner? I kinda like the stock look.
Power Brake Booster carguy68ssrs Jeep CJ Forum 0 07-12-2009 04:16 PM
added power booster to my 85 85cjbeater Jeep CJ Forum 0 09-03-2007 05:25 PM
Power Brake Booster h2obuff Jeep CJ Forum 52 06-17-2006 05:36 PM
Is this a YJ power brake booster brettv Jeep CJ Forum 2 11-03-2004 11:48 AM
YJ power brake booster on a CJ? NJCJ7 Jeep CJ Forum 4 11-10-2003 08:12 AM
