Powder Coating Parts - especially old brake calipers - JeepForum.com
post #1 of 11 Old 02-16-2012, 12:07 PM Thread Starter
WillyC24
1980 CJ7
I had a few items I was going to powder coat, but when I got to the shop, I realized it would cost me a very similar amount to powder coat a few pieces as it would many. The setup cost is a majority of the price.
So...any strong suggestions on parts which should be powder coated rather than simply painted?
Finally, I want to powder coat my brake calipers. I'm assuming that I will need to completely disassemble them, is that correct? Any tricks here from a veteran caliper powder coater?
WillyC24 is offline
post #2 of 11 Old 02-16-2012, 06:41 PM
VACJ7
VACJ7's Avatar
Powder everything!!! Here is a batch of parts I will be powdercoating in my garage this weekend. For me, if it will fit in my oven I will be coating it. Now, having said that I do not plan to PC my calipers simply because they are new and I do not want to take them apart to the point that they can go in the oven.
'84 CJ-7 |
VACJ7 is offline
post #3 of 11 Old 02-16-2012, 06:46 PM
cjjon7
1983 CJ7
+1. Got an eastwood dual voltage PC gun for christmas and I LOVE that thing. Been powdercoating every little bracket, caliper and pulley I can fit in my toaster oven. DONT use your kitchen oven!!!
cjjon7 is offline
post #4 of 11 Old 02-16-2012, 06:51 PM
waterdowg
I like the toaster oven idea.. Never thought about that. Now I'm really thinking about buying a PC gun.
waterdowg is offline
post #5 of 11 Old 02-16-2012, 06:57 PM
VACJ7
VACJ7's Avatar
20.00 off craigslist from someone remodeling their kitchen.
'84 CJ-7 |
VACJ7 is offline
post #6 of 11 Old 02-16-2012, 07:58 PM
waterdowg
post #7 of 11 Old 02-16-2012, 10:31 PM
GlennLever
GlennLever's Avatar
Powder coat everthing you can. Bought my oven off fee-bay
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #8 of 11 Old 02-16-2012, 11:34 PM
walkerhoundvm
1981 CJ8
There are brake component-specific rattle can paints out there, although powder coating is an option, these apparently hold up just as well. I recently installed a pair of calipers that were color-mismatched. My plan is, when I get around to the frame-off rebuild, to paint them using the brake component paints...orange maybe?
walkerhoundvm is offline
post #9 of 11 Old 02-16-2012, 11:41 PM
keith460
Jeep. There's Only One
keith460's Avatar
After reading all the post on this thread, it is easy to see how everyone has gotten hooked on powder coating as I have myself for several years now. I bought the cheap Eastwood single voltage unit and powder coated my OEM manual lockout hubs after sandblasting and cleaning with Acetone as the first pieces. I couldn't believe how quick and easy they had cured to a hard finish and could be installed immediately afterwards, no waiting for paint to cure. Never painted anything again after that, unless it had plastic or some other material that would melt while curing in the oven, that I got off a roadside curb from someone who threw it away during a kitchen remodeling project.
With that being said, powder coating is somewhat of a science as I have learned from trial and error and reading many articles and forums on the subject. I need to upgrade my gun to dual voltage!
Powder coating different thicknesses of metal, aluminum, cast iron will take different heat ranges and time for curing as well as the type of powder being applied. A Infrared Digital Thermometer is a tool that everyone should have for powder coating. The surface temperature of the piece being powder coated must be the same as the curing temperature of the powder and monitored to insure the powder is not under or over cured. You can actually change the color of powder if over heated on thin metals.
To powder coat disc brake calipers, you need long periods of heat because it takes much longer to get the cast iron hot enough for the powder to start to flow and cure. Probably around 40 minutes at 425F or when the surface temperature is the same as the curing temperature of the powder. The powder won't adhere well and may scratch off easily if not heated enough for the powder to cure completely. More importantly, the cast iron part should be preheated beforehand at about 450-500F to burn off any impurity's like oil and and other foreign chemicals that may have been absorbed by the casting. Without first burning off the piece to be powdered, anything that is cast, you will risk getting fish eyes or gas outs. Sometimes they cannot be avoided though.
Take out all rubber seals and anything you don't want powder coated on the caliper, including the pistons. Use silicone plugs to plug all the holes for brake bleeder screws, mounting holes etc. Use a lid, disc, tape or some other means to block powder from entering the cylinder bore of the piston. You don't want to get powder in the inside of the bore and then have it cure because it will be next to impossible to remove. If you accidentally get powder in the bore, use a damp cloth or small brush sponge to wipe the powder away before putting it in the oven. Remember, its not paint you are working with that can be cleaned off with paint thinner or mineral spirits.
Some photos here of powder coated Jeep CJ calipers.... it can be done and heat from the friction generated from applying the brakes has no effect on the powder finish as some people may fear.
1984 CJ-7 Renegade
keith460 is offline
post #10 of 11 Old 02-16-2012, 11:46 PM
DoctorTim
I work at a powdercoating shop. majority of the cost comes from the cleaning and prep work because thats where most of the labor is.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #11 of 11 Old 02-16-2012, 11:50 PM
keith460
keith460's Avatar
Absolutely!
1984 CJ-7 Renegade
keith460 is offline
Powder coating the whole body. NWA_CJ7 Jeep CJ Forum 19 04-05-2010 02:45 PM
powder coating question tomthbomb Jeep CJ Forum 2 11-24-2006 01:23 AM
Powder Coating 84CJ7Mike Jeep CJ Forum 2 12-21-2004 01:38 PM
Powder Coating GADJIT98 Jeep CJ Forum 13 09-29-2004 11:25 AM
powder coating factory parts 83 cj-7 258 Jeep CJ Forum 0 06-19-2004 08:29 PM
