Post your lift size, tire size, necessary modifications, etc. - JeepForum.com
post #1 of 8 Old 03-25-2004, 08:07 AM Thread Starter
Hillbillyd
1980 CJ5
I did a search, but didn't find exactly what I was looking for. My 1984 CJ7 is sagging on the drivers side by about 1.5", so I'm going to buy a suspension lift for it. Are there any modifications necessary for a 4 inch kit? Will I have to get new driveshafts? Brake lines? I'd like to run at least 32x11.50's but would rather run 33x12.50's. I don't do any major off roading, mostly a daily driver with an occasional trail. Do I even need a 4 inch kit if I don't plan on getting radical?
Please post your lift size, tire size, and whether it is a daily driver or not for those of us considering lifts. Thanks!
Hillbillyd is offline
post #2 of 8 Old 03-25-2004, 08:43 AM
RockJeep
Motobilt.com
RockJeep's Avatar
check out www.superlift.com or one of the offroad mags websites i believe they have a chart for what size tire will fit with what ever size lift. I used to have a 4" lift on my 79 CJ-5 and 33's fit without a problem.
good luck
bob
1998 Jeep TJ on 37's, locked, long armed etc
Sales Manager at
RockJeep is offline
post #3 of 8 Old 03-25-2004, 09:01 AM Thread Starter
Hillbillyd
1980 CJ5
I looked at a couple of different charts, but is that for hard core off roaders, or is that pretty realistic for everyone? Thanks
post #4 of 8 Old 03-25-2004, 08:33 PM
only in a jeep cj
I too have the "sagging on the drivers" side thing, but only between 3/4 to an inch.....still enough to bug me! You may want to confirm that it is your springs....I switched my rear springs side to side and even tried another set....no change. I believe the frame is slightly tweaked in the rear......only my back left is sagging.
As far as lifting it, I don't want to talk you out of it by any means, but I am completely amazed at what a stock CJ can do (off road). Because mine is so mint and a daily driver, I choose to keep it stock. I still go off-roading in it and have had folks come up to me and say" I'd swear you weren't going to make that obstacle." I disconnect the swaybars and get lots of flex from the soft stock springs. By running near stock sized tires, I greatly reduce the risk of breaking something. As far as self inflicted damage, in 13 years, I have spun both rear axle hubs (on the street), broke two small limited slip parts, and just worn out parts due to age and mileage.
To change speed here, I am building another Jeep where it's getting 3 inches of lift, front and rear 44's (late 86 and cut down Scout front) and 33's with either 4:10s or 4:56s....don't know yet.
4 inches will be a big change if your not used to it.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #5 of 8 Old 03-25-2004, 11:03 PM Thread Starter
Hillbillyd
1980 CJ5
Thanks for the input everyone! I made the choice today, and bought a 2.5" kit from Rough Country. It was a hard choice, but the dealer lives near me, and it has a lifetime warranty (as I suppose they all do) against sagging or breakage. This way, if something happens, I have very little down time from shipping the springs off to be replaced. I can simply go to his shop for imediate replacement.
As for why I chose the 2.5" kit instead of the 4", it all came down to what I use my Jeep for. It is a daily driver and occasional trail driver. I figure the 2.5" lift will allow me to use 32X11.50 tires for sure, and maybe 33X12.50's if I don't get too radical. Also, I didn't want the extra expense of longer brake lines, longer sway bar links, and the possibility of driveline modifications.
I have a couple of friends who bought these lifts and are very happy with the ride, so I guess I'll find out for myself.
Anyway, just thought I'd post my decision for those who might have been thinking along the same lines as me. I'll post the results after I install it.
post #6 of 8 Old 06-06-2004, 07:12 PM
supersly_jones
your lift
hey...i was wondering how you like your rough country lift...i'm in the market for a 2 1/2 or 4 in lift for my cj-5...planning on 33 in tires...let me know...thanx
supersly_jones is offline
post #7 of 8 Old 06-06-2004, 07:40 PM
83 cj-7 258
83 cj-7 258's Avatar
You can put 33 on with a 2.5" lift if you do some fender triming.
you can go to this web site to see how a tire would do with a lift.
http://www.4wheelparts.com/4wp/assets/!!!---CHARTS---!!!/chart_tire-fitment.htm
83 cj-7 built Chevy 350, sm420, dana 300. Superlift 4in lift, 33x12.50 mikey thompson mtz.
83 cj-7 258 is offline
post #8 of 8 Old 06-06-2004, 08:38 PM
79cj360
i have
skyjacker 5 inch springs
rancho shocks
2 inch conferr shackles
spring over axle
gm 14 bolt
dana 70
and am going with 42 inch tsl's
i also need
custom driveshafts
puttin in
th350 trans
np208 t-case
and a few other goodies.
yes it will be a daily driver, yes i will get tickets. call me what you liek thats my jeep
john
79 cj7
70 amx 360
turbo 350
12 inch lift
39.5's
np 208
re quick disconnects
rancho shocks
cutom driveshafts
snorkel
14 bolt rear
international dana 70 front w/closed knuckles
" damn modification bug bit me hard, so im bittin back!!"
"Go mud or go home"
79cj360 is offline
Need Advice, lift, no lift, tire size, wheel spacers??? darwood112 Jeep CJ Forum 3 03-25-2009 11:55 AM
wheel rim size vs. tire size... hex Jeep CJ Forum 2 03-11-2009 09:10 AM
First post! What size body lift should I get? M79 Jeep CJ Forum 18 07-01-2007 06:59 PM
How much lift for a particular tire size? supraman1990 Jeep CJ Forum 6 04-03-2007 08:28 PM
Rim Size vs. Tire Size Daniel W Jeep CJ Forum 11 12-17-2004 04:32 AM
