Is It Possible ? An Unasked MC2100 question ? - Page 2 - JeepForum.com
post #16 of 17 Old 12-01-2011, 09:52 AM
scrapman
Originally Posted by cj5752 View Post
The venturies are machined into the carb body. If you look down the throat of the carb you will see it is tapered to a point then becomes wider again. this constriction is the ventury. The taper speeds up the air to make it draw fuel through the jets better. If the venturie area becomes to large for the amount of air you are pulling the air speed drops and you don't get as good of vacuum sinnal at the boosters. At this point throttle response gets worse.
I think he is talking about taking the venturi cluster out of a 1.08, and using it in a 1.21, which is a better rebuild candidate for him. He says he has found a 1.21 where the bottom openings are the same size as a 1.08, I don't see why this wouldn't work.
scrapman is offline
post #17 of 17 Old 12-01-2011, 11:57 AM Thread Starter
Oily
Wow ! That makes sense, . Even the rebuild kit exploded view identifies part #37 as the venturie boosters. I need to examine all of my boosters.
I don't have an inside micrometer. I could feel the taper you speak of. Upon visual inspection, I can even see casting marks at the taper. They do look different on my 1.21s with the larger butterfly openings but the 1.21 with the same sized butterflies as my 1.08, look the same.
Oily is offline
MC2100 choke question jp360cj Jeep CJ Forum 3 12-29-2010 08:18 AM
MC2100 / 258 question CrazyHorse6 Jeep CJ Forum 49 10-30-2008 05:47 PM
AMC OEM mc2100 carb question Full Tank Jeep CJ Forum 8 03-12-2008 02:45 PM
Question about MC2100... KrazyGimp Jeep CJ Forum 36 06-27-2006 10:28 AM
mc2100 question 1rockhead Jeep CJ Forum 3 11-05-2005 10:49 PM
