Possible Solutions to Lower Heat - JeepForum.com
post #1 of 21 Old 06-11-2010, 04:11 PM Thread Starter
Keith
Admin
Keith's Avatar
Besides a beefier radiator and electric fan are there any notable modifications or upgrades that make significant heat differences.
A/S/L me
Keith is offline
post #2 of 21 Old 06-11-2010, 04:17 PM
Coiz
1979 CJ7
Like you said, bigger radiator, bigger fan, air shrouds are important. You can also lower your coolant to water ratio as water transfers heat better than glycol. Just keep enough glycol in there to keep the freeze protection you will need for your area. If you have no threat of freezing you can actually run 100% water and just add some water wetter or purple ice to keep the corrosion protection and water pump lubrication intact. That's what we do for our race bikes.
Mike
Coiz is offline
post #3 of 21 Old 06-11-2010, 04:28 PM
h2ojeep
1978 CJ7
Just worked on my this week. It has been getting hot in this 100+ West Texas heat.
I put my fan shroud back on (left it off after a 1 in body lift this winter) and also went from a 4 blade fixed pitch fan to a 6 blade flex fan. It is pulling so much air at idle, I am afraid for small children to walk by for fear of having them sucked in.
Also, dumb me, check your coolant level. I drained less than I re-installed (recovered about 99% when draining) meaning my level was probably low and at least adding to the problem.
h2ojeep is offline
post #4 of 21 Old 06-11-2010, 04:47 PM
mcmud
1983 CJ8
Though generally not thought of as either a modification or upgrade an adequate amount of ignition advance timing along with a well tuned carb will help to hold the temp down.
mcmud is offline
post #5 of 21 Old 06-11-2010, 05:46 PM
turbogus
1978 CJ5
Just to relate a shroud story from my ill spent youth. Way back when I bought a well used '66 Econoline van to keep my junk in. It ran out okay and in fact was the first (and only) turn key vehicle I ever had. The thing always ran hot on the open road. From time to time the company I drove for would have me hold over in Portland, OR where there was one of the few wrecking yards that didn't send their old stuff to the crusher. I found a '65 and a '67 whose parts I occasionally scavenged. One time I saw at the top of a three car stack another econoline~with a belly pan. I recalled from my hot rod days with a '66 Malibu with a 30-30 cammed motor that ran hot~until I installed a shoud. I unbolted the thing and ran it back home to Toledo, OR and bolted it up-from then on it wouldn't come up to full operating temperature on account of all the other cooling mods I had made. (oversized radiator, high flow water pump, etc.)
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #6 of 21 Old 06-11-2010, 07:04 PM
Dborns
I've been wanting to post a question here on engine temp. My '77 AMC 360 has the stock radiator, and a 4 blade fan. I did not get a shroud when I bought the Jeep. With the high heat lately, I've kept an eye on my temp gauge. I must have a 180 degree thermostat, because it gets up to that heat pretty quickly, then stops there. I've not had it get much hotter than that, including tonight when I was on the highway in 90 degree weather for 30 minutes in stop and go traffic. Its only going to get hotter here though, so I wasn't sure if I should do any upgrades to help it stay cooler for longer. It hits 180 pretty quickly, even on 70 degree mornings.
I have drained and flushed the system, and added water wetter to it. Any other suggestions?
Dborns is offline
post #7 of 21 Old 06-12-2010, 09:43 AM
turbogus
1978 CJ5
That's a pretty good sign that your thermostat's working Dborns. 'Betty' goes the same way.
turbogus is offline
post #8 of 21 Old 06-12-2010, 01:55 PM
Bubba Ray
Maybe try some hood vents.
Bubba Ray is offline
post #9 of 21 Old 06-12-2010, 10:55 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
At least a 3-core radiator, factory shroud, replace mechanical fan with a big 7-blade thermal clutch fan from a FSJ.
Beyond that, you can try to move all the air into the engine compartment you want, but its useless if you can't evacuate it. If the engine compartment is a significantly higher-pressure area, the air just won't move effectively. Hood louvers are an outstanding way to make that happen.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #10 of 21 Old 06-14-2010, 10:10 AM
Gunga
1978 CJ7
Hood louvers. www.raceace.com
'78 CJ-7, 401 w/ headers, T-18, 35" muds, 4" lift, MSD ignition box, locked diffs.
Gunga is offline
post #11 of 21 Old 06-14-2010, 10:19 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
Try Royal Purple coolant!!
Purple Ice is a high performance, synthetic, radiator coolant additive. It reduces engine heat by reducing the surface tension of the radiator fluids for improved heat transfer.
Purple Ice fosters optimum coolant flow by helping to prevent formation of scale deposits in the radiator. It also lubricates the water pump seals.
Purple Ice should always be used in conjunction with antifreeze in regions where freezing temperatures occur. Purple Ice is recommended for any water / glycol pressurized cooling system, including those using the traditional green silicate based glycols or the newer OAT or HOAT based glycols.
Street Thunder magazine
endorses Purple Ice
read more
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #12 of 21 Old 06-14-2010, 12:12 PM Thread Starter
Keith
Admin
Keith's Avatar
Anyone have any photographs of hood louvers installed?
A/S/L me
Keith is offline
post #13 of 21 Old 06-14-2010, 12:52 PM
Coiz
1979 CJ7
Oh, I can't miss the chance to show these off. I had mine directly stamped into the hood at a custom Hotrod shop. I wasn't to keen on the rivet on style although I'm sure they are fine. Once I get the Jeep running, I plan to check the under hood temps at extended idle then again at steady cruise with them opened up then check it again with them taped off to see the difference. You can see more louvers in this thread.
Mike
Coiz is offline
post #14 of 21 Old 06-15-2010, 05:10 PM
Bubba Ray
Someone here has some neat hood vents that go on the sides of the hood. No worries about rain.
post #15 of 21 Old 06-15-2010, 05:18 PM
kakai81
Hood louvers
That was a guy from Bali, the vents looked like gills. He did just about everything cool that you could do to a jeep.
If you add better fans and coolant properties, and still can't get the temp down, try a new t-stat. One that opens at a lower temp. At least it'll get the water moving sooner.
kakai81 is offline
cj7 , cooling , engine , heat
CJ Gun Storage Solutions? cfljeep Jeep CJ Forum 12 05-16-2008 07:00 PM
Spare Tire Solutions White92 Jeep CJ Forum 8 04-25-2008 11:00 AM
HD Steering Solutions??? sanmiam Jeep CJ Forum 13 12-21-2007 09:59 PM
Child Seat Solutions? Knight6 Jeep CJ Forum 4 01-30-2005 02:44 PM
A/C solutions pf1130 Jeep CJ Forum 7 08-16-2004 10:05 PM
