Possible Clutch Problems??? - JeepForum.com
post #1 of 7 Old 06-02-2007, 11:05 AM Thread Starter
CJ5 78
I was wondering if some of you guys might be able to help me diagnose a problem. I have a 78' CJ5, 304 V8, 3 spd and just recently the clutch has been making a grinding sound everytime I shift gears. It used to shift very smoothly and now it seems that I have to force it in gear and when I do, it wants to make that grinding sound. What might this be? I just had the clutch replaced last year. Any advice is appreciated. Thanks!
CJ5 78 is offline
post #2 of 7 Old 06-02-2007, 12:13 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Check clutch linkage first. It could need a clutch linkage adjustment or it might be time to put new synchronizers in the trans. If it does it in all gears, and it started suddenly, chances are it is just a linkage adjustment. Get down under your Jeep by the bell housing. There should be a rod that can be adjusted to set throwout free play. Crank it out a bit and see if that helps your problem.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 7 Old 06-02-2007, 12:16 PM
4.7stroker
I would start with a tranny oil change.
Then look into the master/slave cylinders.
Only then after all of that has failed synchros.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 7 Old 06-02-2007, 12:31 PM
jayhawkclint
1970 CJ5
He's got a '78.
post #5 of 7 Old 06-02-2007, 12:36 PM
4.7stroker
I take it they had linkage?
In that case check it's adjustment as previously suggested.
Dwayne
[url]
[url]
post #6 of 7 Old 06-07-2007, 05:21 PM Thread Starter
CJ5 78
Alright gentlemen. I went out and took a look under my Jeep and found a big puddle of transmission fluid on the floor underneath it which explains the grinding sound when changing gears. My next question is other than the drain and fill plugs, where else could the transmission fluid be leaking from? Could this be an indicator of a big problem? The reason I ask is that the transmission fluid didn't seem to be leaking from the drain plug. As always, any input is appreciated.
CJ5 78 is offline
post #7 of 7 Old 06-07-2007, 05:36 PM
slacker92104
slacker92104's Avatar
Is it leaking from the front or rear of the tranny? It may be that one of the seals has gone bad.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
Clutch Problems? Krackalacka Jeep CJ Forum 13 10-22-2009 07:13 AM
Clutch problems? jeepsarecool Jeep CJ Forum 5 03-28-2006 09:56 AM
Clutch Problems DEERSLAYER1407 Jeep CJ Forum 1 11-06-2005 06:03 AM
Clutch Problems??? slimdog21 Jeep CJ Forum 10 07-17-2005 10:15 AM
New clutch = problems, please help! jmerlick Jeep CJ Forum 3 11-08-2004 01:28 PM
