por 15 quantity - JeepForum.com
post #1 of 22 Old 01-10-2008, 08:44 PM Thread Starter
LSUtiger
1980 CJ5
por 15 quantity
about to buy por. Looking at a gallon of chassis coat and 2 gallons of por 15. I will be painting the axles, springs,frame and underside of the tub and maybe engine bay. I will also paint the inside tub but will spray herchuliner before the por 15 dries (so no topcoat needed). It adds up to $500 with shipping so i wanted to do it right.
Thanks,
Brady
PS: I will be asking questions, I have a 72 dana 30 that I want to add the disc brakes from my 1980 dana 30. So I will be replacing all ball joints, u-joints and a brake going through. Also doing the 44 rear. So I was going to atempt my first write up!
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #2 of 22 Old 01-10-2008, 09:02 PM
St.Patrick
1972 CJ5
I haven' used the POR 15 yet but with the prices I have seen that sounds about right. I also have the 72 same set up. Can't wait to see the write up.
Good luck.
St.Patrick is offline
post #3 of 22 Old 01-10-2008, 09:17 PM Thread Starter
LSUtiger
1980 CJ5
Hey Patrick,
How do you like the 3.73 with 31s? I have 33s but they only measure 31" tall.
LSUtiger is offline
post #4 of 22 Old 01-10-2008, 09:19 PM
molsenice
1964 CJ5
it took a quart to do my 64 cj5 frame - used a second quart to cover the axels, springs ( I separated the leafs and then reassembled), skid plates and a couople misalaniouse. bought a six pack of pints for stuf that comes up - one did the windsheild frame and all the top hardware.
IMO you are way over ordering - unless you are doing thirty coats
follow the directions - and WEAR VYNAL GLOVES
molsenice is offline
post #5 of 22 Old 01-10-2008, 09:22 PM
St.Patrick
1972 CJ5
I work about 60 miles from my house and use the Jeep on snowy days. So I still need to be able to get down the Highway at a decent speed. I do some trail riding but nothing to hardcore. for this I think it's perfect. I still have a lot of torque in the low end and a decent top speed. If I went to 33s I would lose a little bit of the low end but my top speed would be more. so for me it's not a big deal. What are your thoughts? Also I only have a 3speed.
post #6 of 22 Old 01-10-2008, 09:29 PM
Floridazed
Floridazed's Avatar
1980 CJ7
MAke sure you metalready the metal and then clean well (1st two steps)
Or you wind up trying to remove the por15 off your frame that will come off with a pressurewasher spray. (current experience)
I'm going to use this kit
Andy
_______________
1980 CJ-7 : 151GM : Stock : In process of restoration (always constant, and something to do.)
Floridazed is offline
post #7 of 22 Old 01-10-2008, 09:47 PM
kbazurpe
kbazurpe's Avatar
1973 CJ5
I did the underside of a tub (2 or 3 coats) and a frame (2 coats) and didn't use more than a 1/2 gallon. Two gallons might be more than you'll need, POR15 is pretty thin.
kbazurpe is offline
post #8 of 22 Old 01-10-2008, 09:53 PM
Floridazed
Floridazed's Avatar
1980 CJ7
Getting your POR15 in smaller units (as suggested above) can be a good idea. You can really open the container twice or so and it will then start to harden. Once opened, storing it long periods aint gonna happen.
Andy
_______________
post #9 of 22 Old 01-11-2008, 05:47 AM
CJ Chet
I saw a good tip on that. Before you put the lid back on the can, shoot the inside full of Argon from a Mig welder. It displaces air.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #10 of 22 Old 01-11-2008, 05:50 AM
Fatman
Fatman's Avatar
2008 CJ7
X2, as I was reading the above I was thinking the same thing.
The POR15 will survive a bit longer but the Chassis Black will turn to a rock within a few days of opening the lid. Use a piece of plastic between the lid when you go to re-seal or you will never get it open again.
Thread Links:
Fatman is offline
post #11 of 22 Old 01-11-2008, 06:10 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Maybe break the order into one gallon of POR 15, a few quarts of POR 15 and 4 quarts of Chassis Black. Although it'll be more expensive to buy the smaller cans, it'll allow you to open cans as needed and avoid having the stuff harden in the can.
That's an interesting tip about the Argon. I always try to have everything ready so I can open the can, pour into plastic container and reseal can immediately to limit exposure to humidity (since POR is moisture cured). I've actually got 2 qts of POR 15 that have been opened before and have been sitting on my shelf for 6 months. I picked them up yesterday and they are still liquid.
BESRK is offline
post #12 of 22 Old 01-11-2008, 07:18 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Once opened, storing it long periods ain't gonna happen.
Originally Posted by Fatman
X2, as I was reading the above I was thinking the same thing. Use a piece of plastic between the lid when you go to re-seal or you will never get it open again.
X3. I've tried the plastic trick, didn't work all that well. The problem is if you get any POR-15 into the area where the lid seals...It's like Ultra Epoxy. You'll bend the f**k out of the lid the next time you try and open it. Which will ruin the rest of your product. Suggestion: If you go with the gallon size, head to Lowe's or HD and pickup a few small paint cans and lids. Pour the POR-15 into them using a disposable funnel to protect the lid area. Open and use only what you need.
Originally Posted by molsenice
...follow the directions - and WEAR VINYL GLOVES
Yup. And old clothes. Or get a throw away set of painter's coveralls. Wear a hat (ya don't want this in your hair-Don't ask). And tarp under where you're working.
I used cheap Chip Brushes to apply the stuff. They do shed some of their bristles though. I don't think ya want to try and clean a brush out after using it...Just my $.02.
"In the end...It's all Hack."
HackFabrication is offline
post #13 of 22 Old 01-11-2008, 07:35 AM Thread Starter
LSUtiger
1980 CJ5
Great advice.
I will be using a metal ready type substance. It is a lot cheaper and no shipping charges on the stuff from Home Depot. The reason I was trying to do all of it at once is the shipping costs were significantly cheaper. I have read about using the plastic wrap under the lid but not the argon idea. I will be spraying the por so it will be cut with thinner. Maybe 1 gallon of POR and 2 quarts of chassis coat?
Patrick-- I think that the 3.73 will be perfect for the 31s. Our trannies have the same final drive gear so they are not that different. If I do go to 33s, I would like to have 4.56 gears.
Thanks again,
Brady
LSUtiger is offline
post #14 of 22 Old 01-11-2008, 08:35 AM
molsenice
1964 CJ5
not sure exactly what they put in there metal ready - but I scored a gallon of phoporuse metal prep from the local paint store - it did seam to prep the surface, but the POR finish instead of being shinny and rock hard as previouse experiance was, turn out dull and soft. - top coat was rattle can and seamed fine. Mabey I forgot the rinse after the metal prep on the windsheild - can't remember
IMO - stick with their product (Metal Ready)and what worked for me was to lay a vynal glove on the lip of the can before the lid - 2 layers - then I hammered the lid into the grove - stayed fresh for over a month - 6 months before I used it.
with spraying - you will use less product, I still think you are way over ordering, but at least you will have plenty to cover everything multiple times
post #15 of 22 Old 01-11-2008, 08:51 AM Thread Starter
LSUtiger
1980 CJ5
how much does it take to cover the inside of the tub and the underside of the tub? I thought that would take a gallon.
Fran how much would you get?
LSUtiger is offline
TF999 trans flush and fill quantity scooter Jeep CJ Forum 3 12-06-2009 12:56 PM
