POR 15/Chassis Saver VS. Rubberized Undercoating?? - JeepForum.com
post #1 of 4 Old 12-24-2011, 10:31 AM Thread Starter
ctappan94
1983 CJ7
I need to put an undercoat on my body tub. What Will prevent rust and look decent for the wheel wells and such? thanks!
ctappan94 is offline
post #2 of 4 Old 12-24-2011, 11:20 AM
gunrun45
1982 CJ7
Why not both? I used POR rust converter that reacts with rust and shuts I down (supposedly). Then I hit everything with Duponts rubberized undercoating (spray can). I did this mid last winter and it's held up great. You can get Duponts product at harbor freight for cheap too
gunrun45 is offline
post #3 of 4 Old 12-24-2011, 06:47 PM
79indcj7
1979 CJ7
Por15 works excellent. Well worth the purchase.
79indcj7 is offline
post #4 of 4 Old 12-24-2011, 10:34 PM
Renegade82
1982 CJ7
Rubberized undercoat works great if you apply it to a fairly clean and rust free surface. I did mine shortly after it was new and as long as you keep it maintained it will do well. But if it allows water to get under it due to scratches or chips, then it tends to hold moisture longer. And if not maintained it will eventually dry out and flake off.
I plan on putting a coat of POR on mine after I sandblast it and replace any rusted areas. I'm still debating whether to put undercoating or bedliner over that. I definitely wouldn't just put rubberized undercoating on bare metal or rusted metal. Use something that "encapsulates" the metal or rust first, to seal out moisture and air.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
Undercoating scotthawk55 Jeep CJ Forum 3 03-27-2011 10:51 PM
Rubberized Undercoating anyone? blacklabel000 Jeep CJ Forum 4 09-30-2008 11:27 AM
has any one used CHASSIS SAVER zachblamercj7 Jeep CJ Forum 2 09-03-2008 08:08 PM
Rubberized Undercoating: Looking for Pros and cons Floridazed Jeep CJ Forum 12 01-13-2008 07:10 PM
Rubberized Oil Pan Coat? 5artist5 Jeep CJ Forum 3 10-05-2007 12:50 PM
